up date on quad cab
Jim
Dec 29, 2006
5
Sorry I didn't mention the truck I have it's a dodge dakota quad cab
with a 5' 3" bed.
jim
quad cab
Well you have a choice of going with the FWC Falcon or our Puma. You can also put an FWC Eagle or our Bobcat on the truck by leaving the tailgate down and the camper would come out to just about the end of the tailgate.
The Falcon or Puma should ride just fine on the truck without any extra work to the suspension. If you went with the Eagle or Bobcat you might have to add some air bags or adjustable shocks. Depends on the current suspension on the truck now. The center of gravity for any of the campers from top to bottom will still be below you cab height. On the Falcon or Puma the center of gravity is just behind your axle on that size truck. With the Eagle or Bobcat it would be a little farther behind the axle.
Either choice I am sure will work for you. Just a matter of how you plan to use the camper and the type of camping that you will be doing.
Sincerely
Ben
www.allterraincampers.com
