Water pump failure
simimike
Contributors
Nov 10, 2005
860
Simi Valley Ca.
On my last camping trip my water pump failed. When I toggle the switch the indicator light comes on but no water pump. Can someone tell me the location of the pump and how to access it? I want to check the ground before I remove it. I have a 06 Granby.
Thanks,
I also have have an '06 Grandby and did some exporing to find where things are mounted. The pump is on the drivers side of the water tank under the shelf in front of the cabinet. To get to it remove the narrow piece next to the water tank door. Then remove the small vertical cabinet piece next to it. The pump is mounted to the outside wall. Before you do this check the fuses.
Thanks for the replies. I removed the panels and was able to access the pump. I removed the faucet screen and it was full of "stuff"(thanks NCF). I cleaned the screen and tried the pump, still no luck. Then I tried the guys sure fire repair technique, I jiggled the wires. Still no luck. Next I will pull the pump and do a diagnostic on it. Put a volt meter on the wires and see if I need a new pump. But Murphy strikes again. I have to go to Sears and buy some square point drivers to remove the pump. Besides it is way to cold to work outside, It has to be at least 60 degrees out there, Brrrrr!
