New guy here with a question about my old FWC. I have an Eagle FWC that I purchased at the Woodland store about the time I bought my Tacoma. I think this was in 2000 or 2001. The plastic valve to the water supply on the outside of the shell broke off some time ago. I managed to remove the remaining piece of the 3/8" PVC nipple from the bottom of the water tank through the hole where the valve used to be. I tried to replace the broken valve with a 3/8" brass nipple and brass ball valve. I've managed to strip the threads in the connection in the bottom of the water tank and now I'm stuck with a water tank that won't hold water. What I need to know is; what is the easiest way to gain access to the water tank? It seems to be under the 2 burner stove and behind the propane valve in the cabinet that houses the breaker panel.
I guess I could slather the brass nipple with silicone caulk and just cram it up into the hole in the bottom of the tank but that doesn't seem like a very elegant or secure fix.
Any advice will be appreciated.
Thanks, Kim
Thanks, Kim
