Shotgun Willie
I'm currently working with Marty on an Ocelot shell build. I've got it all dialed with exception of the wiring. Handy Bob's blog has been my primary source of info thus far in addition to some of the posts here. It seems the primary concern is voltage loss causes by improper wiring and poor / wrong power control components. Speaking with Marty it seems the largest wire he can install for pre-wire solar on the roof is 10 gauge. Reason being, any thicker and the wire flex is too stiff for the pop up mechanism. My initial power needs are: 1) furnace fan during the cold seasons, 2) lighting at night, and 3) charging my lap top computer. Potential power needs in the future: refer, and charging deep cell marine batteries for my trolling motor while dry camping on Cascade High lakes. I'd like to avoid generators if possible.
All this said, my Qs follow:
1) Is 10# wire sufficient for solar pre install?
2) Should I wire for more than one panel?
3) Marty recommends keeping the panel weight below 18lbs total. So two small panels or one large?
4) What wire gauge should I use from a ) truck battery to camper separator, b ) separator to aux battery?
5) I've seen a posting here where someone set up a second panel in a pull out drawer under the cab over / on top of the truck's roof. Is this is a viable option if greater than 10 gauge wire is needed? Seems like a trade-off as sun exposure is limited to when parked.
6) HandyBob recommends atleast 2 6v Trojan batts vs one 12v deep cycle. Thoughts?
Many thanks in advance for helpful info and suggestions,
Colby
Colby
