Air bags for a 2001 7.3 F250 Help FWC Grandby
6 replies to this topic
#1 Dennis535
Dennis535
    Newbie
  • Pip
  • 7 posts
Posted 28 March 2015 - 08:06 PM
The F250 has a 6-inch level lift on it and 35 inch tires (bought it used).
Air Lift or Firestone?  Above leaf spring or on the axle side?  I want to maintain as much axle articluations as possible.
The rear leafs do have the camper springs set up,  I run a 2006 FWC Grandy in the bed which drops the bed about 2-inchs.
#2 Wandering Sagebrush
Wandering Sagebrush
    Free Range Human
  • Site Team
  • 10,619 posts
  • LocationNortheast Oregon
Posted 28 March 2015 - 11:30 PM
I have a 2000 F250 7.3, no lift, original wheels & tire size. I put airbags on for a hard side camper (3,300 lbs), but feel they are not needed with my Grandby. I wouldn't add the bags just for my pop top if starting from scratch.
I am haunted by waters
#3 Dennis535
Dennis535
    Newbie
  • Pip
  • 7 posts
Posted 29 March 2015 - 11:27 PM
It sags 1.5 inches on the passenger side and almost 2-inches on the drivers side, when the camper is in the bed.  Since the truck is 6-inch level lift, it means the back in about 2 -inches lower then the front, cause the front of the FWC granby to be angled up and act like wing.  What air bags did you go with do you level it off completely? How is the ride and articluation of the axle off road?  Are the air bags the typr between the frame and the tire or the in board type between the axle pumpkin and the frame?
Thanks for the relpy.
#4 Wandering Sagebrush
Wandering Sagebrush
    Free Range Human
  • Site Team
  • 10,619 posts
Posted 30 March 2015 - 12:56 AM
The bags have been on since 2000, and I don't remember the brand. My guess is Firestone. I don't get much squat with the Grandby on, but run 10 pounds of air just so they're not empty. With higher pressures, the ride is damn rough. My dentist tells me to run them at 90 pounds, he needs more business. I'm not much of an off-road guy, so axle articulation is not a consideration. The road to the racetrack is about as rough as I care to be on. The bags are between the frame and springs.
Good luck...
#5 Riverrunner
Riverrunner
  • 464 posts
  • LocationWest Valley, Oregon
Posted 30 March 2015 - 07:00 PM
I've got firestones on mine.  They've been on since 06 or so and have been fine.  I installed them for a hard side and have proved valuable even for the Grandby on f350 dually.  It only takes 25lbs or so to level the truck.  A little more when I have the boat to tow.  I've also got a small lift on mine and the bags are between the axle and frame.  I've never been anywhere where articulation has suffered but I'm not going to wheel a crew cab into anything that will need a lot of suspension travel.  If you do, you'll be limiting it for sure.  I got jeep for that.
2022 F350 DRW Lariat Ultimate CC, LB, 4x4, 7.3L
2005 FWC Grandby
2023 Rockwood 2720IK Travel Trailer
#6 Dennis535
Dennis535
    Newbie
  • Pip
  • 7 posts
Posted 04 April 2015 - 07:25 AM
Thx for the reply Riverrunner.  How big is your lift? Curious Still looking at the options. What size tires are you running? To a look at your pics looks like about 4-inch because it is a f 350 with a spring pack.  Did you have to block the back.  Nice looking rig.  Thx for the help in advance.
Edited by Dennis535, 04 April 2015 - 07:31 AM.
#7 Riverrunner
Riverrunner
  • 464 posts
Posted 06 April 2015 - 11:35 PM
I did what was supposed to be a 2.5" leveling kit....ended up with 4+ inches of lift up front and had to replace the 2" block in the back with a 4".  Not a huge deal but I'm glad it wasn't any taller.  I'm running 255/85's KM2's which are a little over 33".  With a dually there isn't a lot of choice in wheels and tires and I didn't want to run spacers in the rear.
2005 FWC Grandby
