Adding a propane compartment, furnace to shell model
13 replies to this topic
#11 liftedlimo
liftedlimo
  • PipPip
  • 25 posts
  • LocationVancouver, wa
Posted 02 September 2016 - 02:39 PM
Even if they have a vent at the bottom of the box inside, as a safety measure to the main vent's blockage, the door venting could be better located towards the bottom.  Propane is heavier than air, right?
Yes, but in reality no. This is a standard "RV" propane door with the louvers on top facing down that has more surface area then all of my other campers combined. If you take a trip to the camper store you will find many (if not most) campers dont use propane vented doors anymore probably because they are more expensive than normal baggage doors. FWC still does and I think it is a good idea to have door venting and also satisfies most RV laws. Im sure there is a law about how many square inches of venting a propane compartment must have. In my experience, most campers use a baggage door with a small plastic vent cut out on the inside. My FWC door had 3 times the venting then my buddy's brand new Lance slide in's plastic mounted vent. My other 2 pull behind campers have exterior bottles.
Yes, in theory, a second vent in case a large squirrel, groundhog or some animal of that size somehow managed blocked the door vents and ate through the propane lines at night without waking me up, another vent would helpful. The only feasible scenario for myself that I can see the door vent plugging up would be if I backed into a snowbank. But, I wouldn't be able to use the camper door if I did that. Have you ever plugged up a louvered vent that is around 1/2 square foot of surface area? Bee's nest plugging the door maybe?
That being said, I am adding a floor drain to my propane box to mitigate the squirrel death scenario, and add the ability to hose out the massive amounts of dust that accumulate on the back of vehicles on those long dusty northern haul roads I like to travel.
#12 Vic Harder
Vic Harder
    Doctor Electric
  • Site Team
  • 4,968 posts
  • LocationCalgary, Alberta
Posted 03 September 2016 - 02:38 AM
"If you don't mind me asking what did FWC want for the door and propane locker?  I am in the process of doing the same thing to my falcon."
I just paid $65 for the box, $48 for the door.
Thanks for all the pics... will be doing this soon too!
#13 osu11
osu11
    Newbie
  • Pip
  • 7 posts
Posted 03 September 2016 - 03:15 PM
Vic thanks for the reply.  I will be ordering the door and locker from FWC on Tuesday.
#14 BillTheHiker
BillTheHiker
  • 307 posts
  • LocationBoise, ID
Posted 09 February 2019 - 06:43 PM
I would like to add propane and a catalytic heater to my 2016 Fleet shell. Problem for me is that mine came with a battery box that is on floor rear driver side and from the pics it looks like that is where the propane cabinet would go. So where would I relocate the battery? Or is there an alternative spot for the propane cabinet?
If you go to my gallery there are photos of the interior.
Edited by BillTheHiker, 09 February 2019 - 06:51 PM.
