Traveling with bikes.... recommendations
34 replies to this topic
#21 OpenSpace
OpenSpace
  • 58 posts
  • LocationColorado Plateau
Posted 15 December 2016 - 03:33 AM
Have you ever had problems with the grease being blown out of the headsets with the NS? It looks like they are positioned just about the right height for that. I have one bike with a roller bearing headset that i have to wrap the head tube to keep it from getting blown out.
No. The crown of the fork rests in the "cradle" of the rack and takes the weight of the bike. It's a really well thought out piece of gear. Bummer is I can't use it with my Hallmark w/o some kind of hitch extension because my camper extends past the truck bed.
www.wildlandtrekking.com
#22 Taku
Taku
    Buffalo Rockface
  • 757 posts
Posted 16 December 2016 - 07:12 PM
we use two different racks. A Yakima Swingdaddy and a Thule tilt model. Using a hitch extender keeps them to where you can open the door enough to get in, or using the swing feature it is no problem. Actually did modify the Thule so the door opens all the way without tilting. I also added extra brakelights to the jack mounts so there is no issue with brake lights/taillights being obstructed by the bikes. We also us a bike cover to keep the dirt/rain off. When you drive 20 or 30 miles of red dust road in UT, then find your brakes don't work cause of all the dust that packed in the cables, the cover saves a lot of maintenance.
2005 Tundra  2013 Ocelot    "Ridiculously comfortable"
2021 Tundra 2022 Cougar Shell Built Out  "Even more ridiculously comfortable"
#23 sportsman
sportsman
  • 31 posts
Posted 19 December 2016 - 08:19 PM
The tandems are a Santana Arriva and a Salsa Powderkeg.  Sounds like I have a couple options.  I was just curious if I could squeeze two single bikes inside and not have to worry about a hitch rack.  I have a thule but it will require being unhitched/removed to get in and out of the camper.  Not a huge deal but an inconvenience.
My wife and I have slid 2 CX bikes and 2 mtbikes into our fleet (not all four at the same time), and now our hawk, along with our daughter's bike.  We normally use our Yakima hitch mount bike rack with a swing-arm, which, unfortunately is a top tube rack, but it s sturdy and easily survives rough dirt roads.  I'd love to switch to a wheel mounted rack, but have't found a swing arm rack yet.  there was a small (one man) company in the LA area that made swing-arms, but he has essentially stopped making them.
Dodge 1500 with 4WC Hawk Shell
#24 sportsman
sportsman
  • 31 posts
Posted 19 December 2016 - 08:20 PM
Second WestCoast on this:
https://www.northsho...oto 4bike18.htm
We're serious riders. Wife used to race. We travel to ride. Had a NS rack about 4 years. Best I've used by far.
Northshore racks, not recommended for road bikes or cx bikes.
#25 WilcoOffroad
WilcoOffroad
    Newbie
  • Pip
  • 8 posts
Posted 22 December 2016 - 11:59 PM
One solution is our Hitchswing.
I have a fleet on order.... any recommendations for adding bikes to the mix?  We do alot of riding.  I was wondering if they would fit inside in the aisle if I take off the front wheels?  We also have a hitch rack but it doesn't swivel out of the way so that could be a pain putting it on and off.  We did order the yakima tracks, just not wild about having them up top....... I would probably drive under some low hanging limb....
Just wondering what others do / recommend.  Thanks
Edited by WilcoOffroad, 23 December 2016 - 12:02 AM.
#26 Squatch
Squatch
  • 1,281 posts
  • LocationOn the wrong side of the mountains!
Posted 04 January 2017 - 12:05 AM
I bought one of these a while back to carry my bikes behind my Smart car. I've been very pleased with it. It doesn't swing out of the way but is simple to load and unload and the arms fold up. It works fine behind the camper with a 9" hitch extension. It has a built in screw down anti rattle pin for the hitch. Lotta bang for the buck.
https://www.amazon.c...r/dp/B0001VO1YY
Just bought a front receiver hitch for the Tundra. I'm curious to see how/if this will work up front.
Edited by Squatch, 04 January 2017 - 12:08 AM.
#27 Hardcastle
Hardcastle
  • 52 posts
  • LocationOgden, UT
Posted 14 June 2017 - 10:42 PM
This is what i use:
https://rockymounts....form-hitch-rack
Rocky Mounts Back Stage Swing Away Platform Hitch Rack
It swings out and away from the door on My Hawk.
2008 Tundra TRD Crew Cab & Four Wheel Camper Hawk
#28 mitch h
mitch h
  • 317 posts
  • Locationbrazil,in.
Posted 15 June 2017 - 12:32 AM
We use something like Squatch uses. our extention is a little longer and we can open the door and step in, on problem.  Mitch
#29 windy
windy
  • 460 posts
Posted 19 September 2019 - 03:06 PM
Kuat or 1up are the sturdiest options I’ve run across. We use the Kuat for our 2 e mountain bikes.
  • 1
#30 buckland
buckland
  • 3,080 posts
  • LocationNew England
Posted 04 October 2019 - 05:23 PM
Some folks look puzzled as I have 2" hitch on the front of my truck that I use to move equipment around and into tight spots in the barn. It is very easy to see where you are going. I also store my camper on a wagon that goes in the barn for winter and that is also easier with this set up. If I get a winch it can be mounted both front and rear depending.
Bicycles... I have a bike rack that goes into the 2" hitch in the front. It is nice as the camper rear door is not blocked and the bikes can stay there with a lock. Visibility is also fine and the headlights are not blocked. A bit more weight moved forward as well.
Edited by buckland, 04 October 2019 - 05:24 PM.
Lordwoodcraft  instagram        Rob
The only people who ever get anyplace interesting are the people who get lost.
Henry David Thoreau
"Work to achieve not to acquire"
