http://www.crcindust...-gal-SX128.html
http://www.saltawayp...om/Products.htm
Edited by PaulT, 13 December 2017 - 07:12 AM.
Posted 13 December 2017 - 02:32 AM
Posted 13 December 2017 - 12:40 PM
It split too much to repair. I taped the edges and rubber coated the problem area. Most likely will have to do the entire edge.
I had the edge coming off the shelf just inside the door above where we store the Porta Poti. Tried hairdryer and the re-glue fixes. Did not hold. However at Lowe's they sell angled pieces of aluminum that fit perfect over the edge. Cut a piece to length and used small wood screws. Looks fine and actually protects the edge.
Also I know it's weird but two of the hinges on a pull down door in the storage over the side dinettte rusted??? Man they rusted to where I had remove the screws to open. It's weird because not exposed to any water? Lowe's to the rescue again... they have exact replacements.
Posted 13 December 2017 - 02:21 PM
2015 Fleet on my 2014 Tacoma. I camped almost every weekend/long wkend in 2015 and 2016, then lived in it all of October 2016, and Dec 2016 - May 2017. Love it!
Only a couplea things: furnace stopped working in the spring. Was a faulty igniter board, which apparently isn't terribly uncommon with these Atwood furnaces. That said, I love my heater! I stopped at an RV shop somewhere in Indiana, and they knew the issue, had to get the part, so I camped in their lot for two days. Easy fix once they had the part.
The door locked me inside and I couldn't unlock it! That was the top lock. I had to climb out the emergency window, then take apart the door lock. I only use the deadbolt now. :-) Oh, also, the screws that hold the latch in on the camper side where the door lock lines up comes loose on occasion. I should probably put some loctite on those screws.
I have had three turnbuckles break - all on the same driver's side turnbuckle. I assume the camper puts more stress on that corner and that's why they break, but why is it putting more stress on that corner? Hmmmm.
AT replaced a bad solar controller. Apparently, FWC has changed away from those controllers.
(I want to upgrade my solar controller and add more solar to my set-up.)
Looks like a List, but really nothing big deal except my solar issues which have been a PITA. I think the fridge draws too much and my 160 solar isn't handling it well. Maybe I'll get myself a solar panel for a present.
I love my camper. It stays on my truck full-time and I camp as often as possible.
Since I moved to Missouri, I haven't camped much and that makes me sad.
https://no-destination.org/ .:. https://razorgirls.org/
2014 Tacoma DCLB + 2015 FWC Fleet
Posted 13 December 2017 - 07:55 PM
I'm so anal I'd buy them and clear coat them.
Posted 13 December 2017 - 10:50 PM
Just did a once-over on my 2016 Hawk and the only noticeable rust that I am seeing is on the two little hinges on the back side of the metal cover on the stove top. Kind of weird but they look like very cheap hinges and I suppose that could be a wet spot on occasion. Not someplace that gets a lot of wipe down to be honest however.
https://www.flickr.c...tos/da_edwards/
Instagram removed my account because I couldn't prove I was over 13 y.o.
