This is more useful and easier to use if there are already Anderson Powerpoles installed on those power using devices that you want to know about.
Just another option.
Edited by PaulT, 14 December 2017 - 09:46 PM.
Posted 14 December 2017 - 05:05 AM
Posted 14 December 2017 - 03:16 PM
If you use either a Trimetric or Victron, you will have a more expensive but more capable instrument for managing your power system. There is a cheaper option for measuring power used by specific subsystems that could be useful. The Powerwerx wattmeter. https://powerwerx.co...tBoCWFIQAvD_BwE
This is more useful and easier to use if there are already Anderson Powerpoles installed on those power usung devices that you want to know about.
I agree the Trimetric and Victron are great but $$$. Useful information can can be had for much less .
Bill Harr 2005 Tundra and a 2013 Hawk custom interior.
Posted 17 December 2017 - 01:30 PM
Posted 19 December 2017 - 01:28 AM
Rando-My new 85L isotherm must be a dud. FWC has agreed to replace it. It runs most of the time even in mild temps and kills my 2 75ah batteries. The 180w factory solar barely keeps up. FWC has agreed to replace it. Hopefully the new fridge will perform more like what you experience even though it is larger. Your post is encouraging..
I run the 130L Isotherm with dual 75 ah batteries and 160w factory panel. Mine keeps up just fine. Keep in mind most of my travel has been in southern California and drive every couple of days. Refer pre-chilled at home but have no problem with it keeping the main compartment in the 30's and freezer in the single digits. I am going to add a 120w portable panel just so the batteries don't get pulled down as much in the hot weather.
2016 Ford F150 SuperCab 4X4 Lariat 2.7 EcoBoost Engine
2016 FWC Hawk Front Dinette Silver Spur
Posted 20 December 2017 - 11:39 PM
I have the small digital volt meter I installed to monitor the batteries (2 AGM) in the camper but did want to know more as to the usage... don't have the deep pocket to buy quality so sprang for the one Bill suggested above. I have the 65L Isotherm and it is quiet and efficient as I have never run into a power problem with the 165 watt solar on the roof. Being a novice electrical person... I know how to set it up but the optimal spot... is it right after the battery on the main wire out?
Posted 21 December 2017 - 01:22 AM
You would want to put the shunt in line with the negative terminal to the battery if you want to know about the status of your battery - but you should check to see if this can measure bi-directional current - if not it won't be able to measure the charge current to the battery (in which case the Wh measurement is kind of meaningless).
2016 Fleet Flatbed
2016 Toyota Tacoma
Posted 21 December 2017 - 01:29 PM
Thanks Rando. I sent an email to their service department asking whether it measures bi-directional current. I'll report back when they do.
Posted 21 December 2017 - 06:32 PM
One of the reviews at the link discusses using two of these to measure charging with one and discharging with the other. That implies that these are unidirectional and that manually doing the math between them is necessary to determine SOC.You would want to put the shunt in line with the negative terminal to the battery if you want to know about the status of your battery - but you should check to see if this can measure bi-directional current - if not it won't be able to measure the charge current to the battery (in which case the Wh measurement is kind of meaningless).
Posted 21 December 2017 - 08:55 PM
I am not sure wiring two of them and trying to subtract the 'Wh' readings is really going to give you what you want, and could actually be more confusing.
The issue with coulomb counting (ie integrating) power meters is that they integrate any small offsets or errors in the measurement, eventually leading to big errors and confusing data. The bi-directional meters have the advantage that at least their errors are the same in each direction - so if your shunt is a little off or the current meter is a little off it effects both the charge and discharge currents equally and the SOC measurement can still be fairly good. Using two separate meters, the errors are independent, so if the discharge current meter reads a little higher than the charge current meter, within a few days the difference will be telling you your battery is empty, even if it is full.
Secondly, even if they were dead-on-balls accurate, you would still end up pretty far off as they don't take into account charge efficiency (about 0.9), which means you need to put 1.1Ah back into your battery for every Ah you take out. Over the course of a couple of charge cycles this will make the math very tricky.
I don't want to be to much of a downer - the amazon or powerwerx meters could be very useful in understanding the power use by a specific appliance, such as your fridge, but don't expect them to be able to replace a dedicated battery power meter.
2016 Fleet Flatbed
2016 Toyota Tacoma
Posted 21 December 2017 - 09:23 PM
