Solar Panel Mount on FWC Roof Question
solar renogy Fleet FWC roof rack
  • Please log in to reply
13 replies to this topic
#1 Josh41
Josh41
  • 152 posts
  • LocationMassachusetts
Posted 24 January 2018 - 09:21 PM
OK, 100 watt Renogy rigid panel is ordered.  Curious how you all have mounted rigid panels on your FWCs.  I have a '17 Fleet with Yakima tracks.  I have one rear roof vent, and do not have one over the bed.  Prefer not to add holes to roof and wish to use the Yakima tracks.
Advise appreciated.
Nissan Frontier 2016 CC LWB, 2" lift, tires, airbags and other stuff
FWC Fleet
Summers Off
#2 Wandering Sagebrush
Wandering Sagebrush
    Free Range Human
  • Site Team
  • 10,589 posts
  • LocationNortheast Oregon
Posted 24 January 2018 - 10:09 PM
There are a couple of ways to bolt them to the Yakima tracks. Assuming you ordered or will make the panel brackets, you can either put track nuts into the tracks (I like the Thule TK 1 nuts), then bolt the brackets and panel to them. Alternatively, find bolts like carriage bolts, whose heads fit in the tracks, fit the brackets and panel over the bolts, then tighten the nuts down to keep things secure.
If I had to do it, I would use the track nuts. If they hold down Yakima bars and canoes, they should hold a 100 watt panel.
I am haunted by waters
#3 whwv
whwv
  • PipPip
  • 24 posts
Posted 24 January 2018 - 10:34 PM
The panel on my Eagle is mounted to the Yakima tracks using four bolts and track nuts.  Makes it easy to move around or remove.  I don't have a picture of mine, but this guy has a similar setup: http://www.wanderthe...cks/#entry84359
#4 takesiteasy
takesiteasy
  • 2,588 posts
  • LocationMinnesota
Posted 24 January 2018 - 11:22 PM
Here's how I did it: http://travelswithro...olar-power.html
  • 1
2011 Tacoma AC TRD
ATC Custom Shell
travelswithrockythedog.blogspot.com
#5 nikonron
nikonron
  • 578 posts
  • Locationowensboro,ky
Posted 25 January 2018 - 12:07 AM
I made brackets from aluminum angle. With your smaller panel you may need to span all the way across with aluminum angle. 1"x1"x1/8" will be plenty.  Ron
#6 Josh41
Josh41
  • 152 posts
Posted 25 January 2018 - 12:12 AM
I think that may be the case, the panel is narrower than the tracks.
FWC Fleet
Summers Off
#7 nikonron
nikonron
  • 578 posts
Posted 25 January 2018 - 12:21 AM
If you get a 150 watt panel it would be long enough to solve that problem.  Ron
#8 rando
rando
  • 1,638 posts
  • LocationColorado
Posted 25 January 2018 - 01:26 AM
If your 100W panel won't span the tracks - it probably makes more sense to sell that panel and buy a longer 120 - 160w panel that will span the tracks than to spend the extra money and weight on aluminium angle to adapt the shorter panel to the tracks.
2016 Fleet Flatbed
2016 Toyota Tacoma
#9 takesiteasy
takesiteasy
  • 2,588 posts
  • LocationMinnesota
Posted 25 January 2018 - 02:40 AM
I agree with this- my panel (160 watt) spans the tracks and made installation easy. Plus the extra capacity is nice. Didn't really cost more either.
2011 Tacoma AC TRD
ATC Custom Shell
#10 ckent323
ckent323
  • 1,227 posts
  • LocationSolvang, CA
Posted 25 January 2018 - 08:11 AM
I have two 100 W  panels that are not long enough to bridge across the Yakima tracks.  I bought four lengths of rectangular Aluminum tubing and mounted the panels to them and then bolted to Yakima rails using the Yakima 8890028 Hardware kit I bought on Amazon.
The mounting is solid and easy to adjust or remove.
Solar Panels On FWC Keystone
For more details see post #3 in the following thread:
http://www.wanderthe...le-rack-how-to/
Regards,
Craig
Edited by ckent323, 25 January 2018 - 08:17 AM.
1993 Dodge Cummins W-250 Club Cab long bed, 2007 FWC Keystone
Also tagged with one or more of these keywords: solar, renogy, Fleet, FWC, roof rack
