Heater Is not working
18 replies to this topic
#11 DavidO
DavidO
  • 42 posts
Posted 18 July 2018 - 04:33 PM
I had a similar problem. It turned out to be the thermostat. I had a hard time finding the problem as when the thermostat was turned down everything looked fine but with the thermostat turned up the problem was apparent. See the photo. I did find the problem with a volt meter. One of the wires to the thermostat should always show 12 volts. The other wire to the thermostat should show 0 volts if the thermostat is off or set below the current temperature. If the thermostat is set to run the furnace both wires should show 12 volts, If they do the thermostat is fine.
#12 Bill D
Bill D
  • 981 posts
  • LocationEdmonton, Alberta, Canada
Posted 18 July 2018 - 11:44 PM
Same thing happened to my thermostat.  Understandable given the wire is moving back and forth each time you adjust the heat.
I fixed it with a crude soldering job.  It works.  If it fails again, I'll do a better job.
Edited by Bill D, 18 July 2018 - 11:47 PM.
#13 Wandering Sagebrush
Wandering Sagebrush
    Free Range Human
  • Site Team
  • 10,591 posts
  • LocationNortheast Oregon
Posted 18 July 2018 - 11:56 PM
A digital thermostat might be a little better for you. I think they’re about $20-$30 at big box stores.. They do require batteries, so a spare is always a good idea.
I am haunted by waters
#14 Old Crow
Old Crow
    Searching....
  • 1,059 posts
  • LocationSouth Central PA
Posted 19 July 2018 - 01:16 AM
FYI to anyone wondering why the mechanical thermostat bases in posts 11 and 12 look different than the one in post 4:    They're different brands.  The one in post 4 is an Atwood model like this 38453 one in the Panther RV Products web site
I believe the ones in photos 11 and 12 are White-Rodgers models, perhaps model M30 (but, again, I'm just trying to identify them from the photos)
As to digital thermostats, this Non programmable digital heater thermostat thread has a lot of good info on the subject for anyone looking to change from mechanical to digital.
Edited by Old Crow, 19 July 2018 - 01:20 AM.
'01 FWC Hawk shell on a '13 Tundra Double-Cab  + '19 Ford Transit van with Quigley 4x4 option
#15 Bill D
Bill D
  • 981 posts
Posted 19 July 2018 - 01:55 AM
I prefer the analog thermostat.  I have a spare digital unit that I chose not to install.
I like being able to reach down from bed to make a minor adjustment without having to see what I'm doing.  I actually never look at the temp setting.  I also like the no battery thing being our temps get so cold.
#16 DavidO
DavidO
  • 42 posts
Posted 20 July 2018 - 04:21 PM
I hate to admit it but this actually happened to me twice. I found and replaced the White-Rogers thermostat a few years ago and I forgot about it. When it happened the first time I bought a new digital thermostat the same one that FWC had changed to. https://www.amazon.c...0?ie=UTF8&psc=1  I did not install that new digital thermostat as it was run by a couple of AA batteries. I did get a new White-Rogers just like the old and everything was great for a couple more years until I got a call from the wife who had taken the camper out without me. Honey the heater won't work.
When I first installed the digital thermostat it didn't work. The batteries that came with it had gone bad from just sitting. I tried some from my supply at home, they worked for a couple of days and they also had sat around for to long. Finally a fresh pack of batteries and it has been over 6 months and I am now convinced that the digital thermostat is so much better.
With the old mechanical thermostat to use it we pretty much used it as a switch. If we wanted heat we would just give it a shove when we had enough heat we would shove it towards off. This was particularly true before getting up in the morning. We were just using the thermostat as a manual switch for the heater. All this shoving broke the wire in the thermostat TWICE.
With the new digital thermostat you push the button and it tells you the current temperature. With a couple of pushes you can add just a degree or two to the temperature and this works to keep the temperature under much more control than our previous method. I sure do like the digital thermostat so much better. My recommendation, change to a digital thermostat and carry a couple of fresh batteries.
#17 krs1
krs1
  • 83 posts
Posted 04 August 2018 - 07:24 AM
Went by Atc and Marty diagnosed as a bad thermostat. Replaced in 10 min then back on the road with a working heater!!! Thanks for the info
#18 Old Crow
Old Crow
    Searching....
  • 1,059 posts
Posted 04 August 2018 - 01:33 PM
Thanks for the follow-up... always appreciated!
#19 Wandering Sagebrush
Wandering Sagebrush
    Free Range Human
  • Site Team
  • 10,591 posts
Posted 04 August 2018 - 01:48 PM
Marty and the ATC team are fantastic! Thanks for keeping us in the loop!
