Bailey's 2018 Raven Shell - Build & Photos
#71
Posted 24 April 2019 - 07:17 PM
#72
Posted 06 May 2019 - 12:00 AM
#73
Posted 13 May 2019 - 02:33 AM
@BaileyJ - can you share where you ran the external WeBoost antenna into the camper? Did you drill a hole or run it through a turnbuckle door? Great build by the way!!
2003 Ford Ranger 4X4
2018 FWC Fleet Shell
#74
Posted 14 May 2019 - 06:54 PM
the WeBoost cable is routed into the electrical compartment above the turnbuckle openings on the driver's side. A hole was drilled and the wire was run directly into that compartment.
Thanks!
#75
Posted 21 May 2019 - 10:06 PM
#76
Posted 25 May 2019 - 04:31 AM
#77
Posted 25 May 2019 - 07:08 PM
Edited by BaileyJ, 25 May 2019 - 07:17 PM.
#79
Posted 06 June 2019 - 11:24 AM
This is a great concept. I hadn't heard of Goose Gear. I did a very basic storage system after removing the seats in my Ranger, but nothing like the Goose Gear system. I'll be curious to hear the final weight of the unit. I used peg board as my decking to minimize weight and increase ventilation. I considered adding drawer hardware for ease of access, but opted nit to as a weight savings. So I have to remove everything on the top deck to get to the storage area.
Maybe the compromise is lighter drawer slides. Looks like your hardware is aluminum, I was considering the typical steel slides found at Loew's and Home Depo.
Please keep us up to date with your project and final weight.
2016 F150, FX4, XLT super cab
2019 FWC Hawk Shell
2009 Ford Ranger 4x4, XLT, Supercab total loss on 7/30/19
2014 FWC Shell total loss on 7/30/19
#80
Posted 07 June 2019 - 12:41 AM
I'll try to get a final weight after coating.
It's much lighter than the factory seats, The 60% portion weighs around 89lbs
