Painting Camper resources
7 replies to this topic
#1 Anchored nomad
Anchored nomad
  • 53 posts
Posted 12 May 2019 - 11:14 PM
Anyone have links, resources, etc about painting your FWC? I have a 2006 Eagle that I want to paint grey. Anyone have experience painting theirs, what kinda paint, did you do it professionally, etc?
Thanks!
Edited by czukie, 12 May 2019 - 11:15 PM.
#2 BBZ
BBZ
  • 666 posts
  • LocationGolden, CO
Posted 13 May 2019 - 04:49 PM
I had an old Fleet that I painted. Just used Rustoleum spray cans from home depot.. it came out great, people were shocked it wasn't a new camper.  pretty easy and quick, did 3 light coats if I remember correctly.
2023 F-150 Scab HDPP + 2013 Grandby Shell +
https://www.wanderth...ect-90s-granby/
#3 BBZ
BBZ
  • 666 posts
Posted 13 May 2019 - 04:53 PM
Here is a pic of it..
#4 dandone13
dandone13
    Newbie
  • Pip
  • 1 posts
Posted 25 May 2019 - 01:12 AM
i used Tremclad colour: Gloss aluminium  bunn.png
Edited by dandone13, 25 May 2019 - 01:13 AM.
#5 a8ksh4
a8ksh4
  • 109 posts
  • LocationSacramento, CA
Posted 04 June 2019 - 05:32 AM
3 light coats
I'm more the 1 and a half heavy coats type, but I like the spray Rust-Oleum too. It come to out great if you prep the metal properly before you spray it.
#6 BBZ
BBZ
  • 666 posts
Posted 04 June 2019 - 06:51 PM
yup.. many ways to do it.. here is colorado with the low humidity you can re_coat pretty quickly if you go light.. advantage of being able to get a lot done quickly.. unless its windy.. that screws it up..
#7 Anchored nomad
Anchored nomad
  • 53 posts
Posted 13 June 2019 - 10:28 PM
How did you prep yours?
#8 a8ksh4
a8ksh4
  • 109 posts
Posted 16 June 2019 - 04:47 PM
Cleaning and fixing any damage
* Mineral spirits worked well to remove old butyl residue
* Gasket remover and mechanical scraping to remove silicone crap.
* Not sure if it's best, but I wiped down the silicon areas with acetone, changing rags a few times, to try to remove any residue.
* Scrape and sand off any flakey damaged paint.
* Make any repairs or patches to holes
* Wipe the whole thing down with wax and grease remover, changing rags a few times as you go. Mainly trying to remove anything that hurt adhesion or cause fish eye and taking care not to spread anything around in the process.
* Rough any bare metal with sanding pad and prime with self etching zinc primer.
* Rub the whole thing down with sanding pad and wipe off any dust. use waxed cloth for this is you're fancy, or just damp paper towel.
* Mask, wet down the floor for dust, and spray new paint!
* You can sand lightly between layers if you're doing this in the driveway and need to remove bugs and crap that landed in your first coat.
