Tire and suspension air bag pressure for a Frontier with Fleet?
ture pressure suspension air bags Nissan Frontier
7 replies to this topic
#1 whynot
whynot
    Newbie
  • Pip
  • 8 posts
  • LocationBremerton, WA
Posted 18 July 2019 - 02:57 AM
We have had our camper for six months and are pretty happy with it.  However, it feels a bit more bouncy than I think it should.  If you have a similar rig I would be very interested in knowing what air pressures you find optimal.  Thanks!
#2 whynot
whynot
    Newbie
  • Pip
  • 8 posts
Posted 18 July 2019 - 03:16 AM
Hmm, I have just found a great thread on tire pressure on this site so now I just need thoughts/recommendations on suspension air bags.
#3 drumwood
drumwood
  • 97 posts
Posted 18 July 2019 - 02:25 PM
I have a 2008 Frontier with a ATC Bobcat shell. Cooper E rated tires. 45 lbs front, 55 lbs rear. Airbags at 40 lbs left (furnace/propane side, so heavier), 35 lbs right.
It seems to ride good. I set the air bag pressure by what it takes to bring the rear tire clearance back to what it would be unloaded.
#4 Casa Escarlata Robles Too
    C'est la vie
  • Site Team
  • 9,296 posts
  • Locationmonterey bay area
Posted 18 July 2019 - 06:15 PM
Not exactly the same,but similar.
I have a 2002 Tundra AC TRD 4X4 with a full Bobcat.
Firestone air bags and 265 75 R16 D rated tires.
I keep 40# front 45# rear and 30# left airbag 20# right airbag.
This works well for me.
I also keep a eye on the center tread wear to see if I am
over/under inflated.
#5 Kokopelli
Kokopelli
  • 134 posts
  • LocationDurango, Colorado
Posted 18 July 2019 - 10:33 PM
I have a Frontier King Cab with an Eagle.  BFG KO2 tires at 42 front 50 rear.  Air down when on rough 4x4 roads.  The E rated tires make a huge difference.  Air bags set at 60 left, 45 right.  This was what it took to bring the height up to what it was without the camper - although this was with regular tires - haven't done that with the KO2's (probably should),  but that air pressure works well.  Hardly any bounce at all and feels very stable.
Rick 2007 Nissan Frontier King Cab 4x4 NISMO. Ride-Rite air bags. 2008 Eagle
#6 JHanson
JHanson
  • 489 posts
  • LocationTucson and Fairbanks
Posted 19 July 2019 - 12:50 AM
I usually keep about 35-40 pounds in the Boss air bags on our 2012 Tacoma Extracab with FWC Fleet. If you're using similar pressure and still feeling a lot of bouncing, the problem could be with your shock absorbers rather than the bags and springs. The suspension shouldn't cycle (bounce) more than once or twice over a bump. If it's pogoing, that indicates a lack of shock control.
  • 1
#7 whynot
whynot
    Newbie
  • Pip
  • 8 posts
Posted 19 July 2019 - 04:41 PM
Thank you all for your input; much appreciated.  We had BFG KO2 tires installed yesterday and they set pressures at 50psi. (they replaced P-rated tires)  Already it is handling much better, so we will now tinker with adjustments.
Cheers!
#8 Casa Escarlata Robles Too
    C'est la vie
  • Site Team
  • 9,296 posts
Posted 19 July 2019 - 07:31 PM
Just getting rid of those "P" rated tires was a great first step.
They are "car" tires now LT ones.
