Hi:
Thanks for the ideas. That is a great build website. The photos with your rig in the desert are beautiful. Really nice photos.
I will eventually end up with a 4wd 6 Cylinder Tacoma when this truck wears out. But it does not seem to be wearing out; still solid.
I should say that this is a 2wd, 2.7 4 cylinder AC cab. The basic work truck. I am confident in the motor, although it's only 159 hp. I have towed 3000 pound boats with it and no difficulties. It is the tires that are the problem. A high load rating or E-rated is impossible to find.
I went with AT style as it has a higher load rating and is still on a 15" rim. I can't find a non-AT style tire anywhere that has a load rating anywhere near an E-rating. They do not exist.
When I look here for the BF Goodrich All-Terrain:
https://www.kaltire....ml#productSizes
I see a few sizes on 15" rims:
31/1050R15(109S)
35/1250R15(113Q)
I think the first two will not fit the 2wd basic AC Tacoma; the tires will rub. The first two tires are usually on Jeeps as far as I can tell.
The third size one has a 111 pound higher load rating than the Goodyear Wrangler I was thinking about; 1653 vs 1764.
The last size has a 104 rating which is 1984 pounds. But I think rubbing with the 235/75/R15.
Then the BF All Terrain T/A K02:
Again the 100 load rating and a 104 load rating.
Either of the 215/75/R15 would be fine?
Thank you!!
Edited by Upwind Hacker, 17 November 2019 - 02:12 PM.
