Last question before ordering
#1
Posted 08 March 2012 - 03:55 PM
- the basic lights, no added options. with most of my camping spring- fall (long days), and wont use the lights for more than an hour per day max.
- fantastic fan - used to move a little air around, but with most camping at 8,000 ft or higher, not likely to be used often
- factory furnace - I really have no idea how much I will use this, but don't expect a lot. Its really for those few days a year where I might be in really cold conditions.
- frig - plan on getting the compressor that requires electricity
- recharging of misc stuff like computer, camera batteries, ipod, etc
I usually drive at least 30 minutes per day when I'm out, so am seldom sitting in one place. Usually have good solar conditions.
I'm been thinking of getting one battery plus solar, but wonder if I should get two batteries plus solar. My concern is not the added cost, but a second battery adds another 50 lbs.
I drive a 2006 Tundra and will be getting a Fleet.
#2
Posted 08 March 2012 - 04:07 PM
Sunman2003 Four Wheel Camper -Hawk
2023 All Terrain Camper - Panther 2006 Toyota Tundra Double Cab Limited 4WD
2017 Toyota Tundra Double Cab Limited 4WD
#3
Posted 08 March 2012 - 04:09 PM
#4
Posted 08 March 2012 - 04:18 PM
I'm looking at placing my order in the next few days and have a question about how much battery/solar I need. Here are my accessories that require energy:
DonC
No hot water or is that standard with this model now? I was talked into getting my set-up and I've ever so glad Stan did-one of the best things i got-I like my three-way frig-only had one problem in 6 years, and I had solar back up when it went out-kept the beer cold, lost the freezer though! Two is always better than one and don't end up a few years later like me wishing I'd bought more neat wigits, when I would have not noticed the $ in the whole $-buy it now and you will not regret it later. Oh yeh-the awning-still love it, except in windstorms!
Smoke
I
#5
Posted 08 March 2012 - 04:24 PM
#6
Posted 08 March 2012 - 04:34 PM
Man, there are a lot of variables that make that a tough question.how does one battery plus solar, compare to two batteries? Is one combination better than the other?
If you're camping in shade or if it's cloudy then you'll do better with two well-charged batteries than with a battery and a solar panel.
On the other hand, if you're in a sunny area then you could stay indefinitely in one spot with a large-enough solar panel -- something you couldn't do with even multiple batteries that weren't being recharged.
#7
Posted 08 March 2012 - 04:40 PM
Two batteries, whether you go solar or not. You won't get much out of one battery should you not have the solar for any reason.
Good Camping, Paul
#8
Posted 08 March 2012 - 05:47 PM
#9
Posted 08 March 2012 - 07:43 PM
Your situation I might say one large battery (ie get a 100+ah, not a 70ah) and solar may make for a good combo. Assuming it's sunny you can sit if you want and even if you don't sit it means you won't cycle your battery as deep so it'll last longer. If its not sunny you're moving around anyways so it'll charge it up. Two batteries is if you want to be able sit somewhere for a longer than a weekend in my mind or will have some high draws.
