Atwood 8516-III Furnace Question
#1
Posted 18 November 2010 - 06:00 AM
By following a spec sheet for this Atwood unit there should be 2 wires that flow from sail switch , 1 to Limit switch, one off to another stop. 1 should be blue the other either blue or white. I follow one wire that seems to go into camper, the other that goes to what seems like a 5 prong nickel sized unit attached in viewable area next to fan unit. not comparable to my dime sized 2 prong unit that I purchased as my limit switch.
My question is do I have to remove furnace to get to limit switch? Or maybe did I recieve the wrong limit switch from RV store, and am actually staring at limit switch?
#2
Posted 18 November 2010 - 03:21 PM
You can also find it by following the wire from the sail switch to the limit switch - they are connected if I recall....
I don't see a way to get to mine without taking out the blower assembly.
#3
Posted 18 November 2010 - 04:35 PM
[/quote]
Thats what I was afraid of ! Thanks, I did see a blue wire heading from sail switch torwards the rear, I just didn't want to start pulling things out.
#4
Posted 18 November 2010 - 04:55 PM
http://www.wanderthe...hp?/topic/3197/
best of luck.
2003 Ford Ranger FX4 Level II 2013 ATC Bobcat SE "And in the end, it's not the years in your life that count. It's the life in your years."- Abraham Lincoln http://ski3pin.blogspot.com/
#5
Posted 18 November 2010 - 07:14 PM
On a sadder note, suddenly my fan is not working again. That could be my fault though. I was about to put ear next to exhaust port to see if I could here the clicking of furnace trying to light. I put my hand up to the exhaust vent and suddenly the fan died, although covering exhaust with hand I in no way sealed it. Like I said, could be a coincidence.
#6
Posted 01 December 2010 - 02:06 AM
#7
Posted 24 February 2011 - 12:37 AM
#8
Posted 24 February 2011 - 01:22 AM
2016 F-150 FX4 XLT SCab | Ingot Silver | 6.5' | 3.5EB | 3.55 w/rear locker | Tow | IBC | 7050# GVWR | 1945# Payload | 36Gal | BFG A/T KO2 LT275/70R18E | Timbrens
2022 FWC Hawk Silver Spur | Front Dinette | Cassette Toilet | Cooktop | Hot Water | Outside shower | CR850 fridge | 160W rooftop solar panel | 15A MPPT controller | Dual 90AH AGM batteries | Yakima Rack | 2 Maxxair fans | Furnace | Fiama side awning | Mechanical Jacks
#9
Posted 24 February 2011 - 01:43 AM
Go to Home Depot...Electrical section...ask for a 10-in-1 (might be called 11-in-1)screwdriver. You'll find a square bit at one end. I keep one in the camper. Has a bit for almost anything.So now that I have removed plate attached to limit switch, I am having a tough time finding square tool to remove the 2 screws. No luck at Sears, home depot, or Ace hardware!
John
#10
Posted 24 February 2011 - 05:25 AM
http://www.craftsman...=2&blockType=L2
-Vic
"I took the road less traveled. Now I don't know where I am"
2014 Dodge Ram 3500 diesel & Hallmark Everest. (Former Rig - 99 Ram 2500/ 2000 Sunlite Eagle pop-up)
