Sliding Window Screen
#1
Posted 31 January 2011 - 11:54 PM
Here is a pic of where I am installing a microwave.
#2
Posted 01 February 2011 - 12:17 AM
#3
Posted 01 February 2011 - 12:38 AM
I like that screen. I might have to abscond, uhh , I mean borrow that idea. The frame looks like some type of plastic. Is it?
Yes, it is ABS plastic....and by all means...."steal shamelessly"!
#4
Posted 01 February 2011 - 02:10 AM
I'd like to see a picture of your microwave installation when you get it completed. Thanks.
2010 Ford F250 4X4; 6.4 Powerstroke Diesel; Warn 16.5 winch; Airlift Springs; Transfer Flow 47 gal. fuel tank, BDS 4" lift kit, BDS dual steering stabilizer with upgraded Fox 2.0 shocks, Toyo 35X12.50X18 Open Country M/T tires, Pro Comp wheels; 2008 FWC Hawk Camper; 2000 Toyota Tundra.
#5
Posted 01 February 2011 - 02:57 AM
#6
Posted 01 February 2011 - 11:07 PM
Also, what thickness did you use?
Thank you!
#7
Posted 02 February 2011 - 11:53 PM
Mike
#8
Posted 03 February 2011 - 01:34 AM
It is 1/8" ABS. I ran a bead of silicone around the frame but for the most part the fasteners hold the screen in place. Silicone does not adhere to ABS all that well. You might look for a different adhesive.
Mike
Since PVC glue is used on ABS drain pipe, I think that would work quite well!
#9
Posted 03 February 2011 - 05:35 PM
#10
Posted 03 February 2011 - 05:56 PM
I was sure that I have seen glue that does both.
