Ive finally got started digging into the camper I posted a quedtion about window seals and thought I would contain all this in one post.
Question # 1
My dinette table wont fit in the bench grooves to make up the bunk. Previous ownerhade made up some plywood slats to cover the span. So what gives? There is no hardware on the wall or ceiling to mount it if it wasnt intended to be used as a bunk support.
#2
All I have for interior lighting is 2 dome fixtures. One over the table and one over the stove. When I plug it in to the garage they work. Will they work on 12 volt also? I do have a breaker panel in the unit and have not tried running of a battery if thats even possible.
#3
I was aware of the Perelli weatherstripping sealing the two halfs but I have more weatherstripping that is mounted on the top of the lower box that is capped in wood trim running all the way around on the interior. What is that? it looks like cloth of some kind. Should that be Perelli also?
Thats all right now but Im sure to have more.
Bob
