Help identifying solar plug type
Solar wiring
  • Please log in to reply
12 replies to this topic
#1 Horseshoe
Horseshoe
  • PipPipPip
  • 43 posts
Posted 02 April 2017 - 07:03 PM
I have a 2011 Cougar which appears to be prewired for portable solar. I recently purchased a 160W portable panel and am hoping someone can help identify what is needed to plug into the camper. Can someone tell me what this piece is called? Is there a standard size? The guys at Home Depot left me more confused than when I walked in.
Thanks!
#2 Wandering Sagebrush
Wandering Sagebrush
    Free Range Human
  • Site Team
  • 10,591 posts
  • LocationNortheast Oregon
Posted 02 April 2017 - 08:00 PM
Two pin SA E
I am haunted by waters
#3 Horseshoe
Horseshoe
  • PipPipPip
  • 43 posts
Posted 02 April 2017 - 08:02 PM
Thank you!
#4 Durango1
Durango1
  • 532 posts
Posted 02 April 2017 - 10:21 PM
Any NAPA auto parts store has them.
#5 ski3pin
ski3pin
    Belay On
  • Site Team
  • 15,340 posts
  • LocationSierra Nevada Range
Posted 02 April 2017 - 10:30 PM
https://www.amazon.c...CGWCNWKZM30W3XM
#6 PaulT
PaulT
    Need gumbo
  • 2,612 posts
  • LocationHillsboro, Oregon
Posted 03 April 2017 - 04:13 AM
Be sure to determine the rest of the wiring.
For example, do the interior wires go straight to the battery, or to a solar charge controller?
Does your solar panel have a solar charge controller attached to the panel?
There needs to be one solar charge controller between the solar panel and the battery. If you hook the panel directly to the battery, you will soon need another battery.
If you are new to solar power in an RV, Handy Bob Solar is a good place to visit. https://handybobsolar.wordpress.com/
Of course, there is a lot of good info on this site. It can be useful to read before hooking up wires.
  • 1
#7 BrianG
BrianG
  • 196 posts
  • LocationNorthern Nevada
Posted 03 April 2017 - 04:16 AM
Zampsolar.com has an excellent 15' extension cable for your portable panel with 2 pin SAE fittings on both ends.
  • 1
2018 Ram 3500 Mega Cab 4x4 Diesel, 2015 Hawk Silver Spur Exterior, Front Dinette
#8 craig333
craig333
    Riley's Human
  • 8,022 posts
  • LocationSacramento
Posted 03 April 2017 - 11:01 PM
Be careful with those plugs. There have been some where the polarity wasn't what it was supposed to be. Don't assume its correct just because it only fits one way.
#9 takesiteasy
takesiteasy
  • 2,588 posts
  • LocationMinnesota
Posted 04 April 2017 - 03:40 AM
 I was going to mention the polarity issue also. Just something to be aware of when connecting two plugs together. One needs to be the reverse of the other.
2011 Tacoma AC TRD
ATC Custom Shell
travelswithrockythedog.blogspot.com
#10 Horseshoe
Horseshoe
  • PipPipPip
  • 43 posts
Posted 05 April 2017 - 02:47 AM
I had the same concern on the polarity. I'll give ATC a call and see if they can confirm which is which. Sure will be nice if I can use that Zamp extension, although I'll have to solve the other end of the puzzle wiring it to the controller.
Its a solarcynergy from solarblvd.com. The verdict is still out but I really hope to use this on an upcoming boondocking trip to the north rim area in May.
Also tagged with one or more of these keywords: Solar wiring
