If we’re looking at the area where the isolator was installed and the wiring is like my 2021 Grandby was from the factory, one white wire is connected to the hot bus of the 12 volt dc fuse block, and the other is the positive wire from the original truck connector jacketed 3 conductor wire which was white positive, black negative, and green running lights.
That leaves the OTHER white wire in this picture. I'm a bit puzzled over that one. Is that the wire you have wired/taped together with the red one it was joined do in this pic? Looking at the wiring diagram, the only place two wires are shown like that is at the Main Battery, and Aux battery +ve posts. Since we are IN the camper (The auxilliary system), this should be the Aux side of the picture. BUT, that red wire goes to a breaker we confirmed as connecting to the TRUCK (MAIN) battery. Or am I missing something????
Edited by Jon R, 11 November 2023 - 09:01 PM.
