Measure the charging voltage before and after pressing the boost button on the boost dongle. If it does not increase to near 14.6 volts, then the dongle is defective or there may be a connection error with the dongle.
On my PD9130 charger, I press & hold the boost button to cycle thru the modes. It increases the charging voltage from near 13.6 volts to about 14.6 volts and the current rises to near 30. The booster will keep the charging voltage and current elevated for up to 4 hours.
Measure the charging voltage directly on the battery terminals.
Mine cycles between 2 modes. It is 14.6 ~15amps in “boost” and 13.6 ~3amps in float.
