1993 T100 offgrid 4x4 truck and camper $32k
yotacamper
Sep 1, 2023
Posts
3
Thanks for checking out this listing for our super rare and unique Yota Camper! It gets a lot of looks and compliments everywhere it goes.
Our photos seem too large to upload here, check out our google photos album for a better look
https://photos.app.goo.gl/bdpAi6U4E2qEhCuT9
-Built on a 1993 Toyota T100, 3/4 ton, 4x4, stick shift(Manual trans), 5 speed, gas, 3.0 V6 engine.
-Low mileage given its age: 192,250 (just 6400 miles a year)
-Lived its life in Utah, garaged in the winter and used for summer desert camping trips by the previous owner. We bought the truck in January 2022 and finished our flatbed conversion & camper box by September 2022
-This is a 8' flatbed with the box attached to it, it is demountable so you have a standard flatbed truck too.
-Designed & built for living, with a 5kw diesel heater, Dometic 12v Fridge, 200ah Battle born Lithium battery system & 200 watts of Renogy Solar panels.
-6ft 2" standing room inside the camper with a full size bed. & large U Shape seating area, a super comfy living space.
- Checkout the link at the bottom for a high res photo album including build shots of the frame and camper.
- We have driven only 6500 miles in this rig since we finished it, it is in impeccable condition.
- 3 keys for the truck, 2 keys for the camper
Camper - Designed and built purposefully by an engineer & sprinter van conversion company owner.
Built from 16ga steel 1.5" x 3/4 profile, sealed in black primer & paint.
Exterior cladding is 'Dibond' Aluminium Composite finished is Raptor paint with Aluminium edge trim, strong enough to walk on the roof.
Insulated with 1.5" of Rockwool 'Mineral' wool insulation
Interior & exterior fastenings high quality stainless steel rivets
Interior mostly birch, 1/4 inch ply
Cabinetry mostly birch, 1/2 inch ply
Fully solar powered Lithium Battery bank for plenty of power anywhere.
Full roof rack for surfboards/paddleboards/kayaks/canoe
Rear fixed ladder for roof access
Basic composting toilet
Birch ply table top & kitchen countertop, finished in 5 coats of Polyurethane
Lagun swivel Table (removable & stowable to create more space if the table is not needed; marine design)
Aluminium extendable steps which detach and create easy access to the camper, Made by 'Brophy' 250lbs rated - Diamond plated
Kitchen: - Spacious kitchen with plenty of prep and cooking space
2x burner propane fixed stove top with easy to clean glass finish
Black anodized sink with copper tap & Whale foot pump (marine style)
6 gallon fresh & 6 gallon waste water tank
55L Dometic CRX 55 12v, super efficient fridge
4x Large drawers for cutlery, pots/pans, food
Living space: Comfortable U shape seating style for up to 5 people, ideal for dinners inside & plenty of space for those cold or rainy days.
Diesel Heater 5kw with remote control & thermostat(super warm!)
Victron Energy - Solar Controller 100/30 Renogy - 200W Solar Panels - Blue Sea Systems 12v Fuse bar
Victron Energy Engine 2 Battery Charger - Orion 30 amp (Charges whilst you drive)
Victron Inverter - 110V Power anywhere, without hookup needed. (800 Watt Phoenix Inverter)
Curtains custom with reflectix insulation made by Horizon Designs
3x large underbed storage cupboards
2x large seat box storage areas
1x smaller seat box storage area
2 large, tinted, opening windows with bug mesh
Fantastic fan vent with 5 speed modes & bug mesh
2x Portholes windows
RV Door with 2 locks & key, privacy glass finish
Lots of natural light!
4x USB Outlets
2x 110v Outlets
1x USB C outlet
6x warm glow ceiling LEDs
2x LED Light strips, warm glow
2" thick comfortable seating cushions with washable removable covers
Bed: Full size, memory foam mattress
75"L x 54"W x 6" thick
Flatbed truck frame: 8' x 6' in size
Custom welded in SLC & powder coated by Full Blown coatings
4x aluminium undermounted toolboxes
Reversing camera with screen
LED Signal & brake lights
Truck - Super clean & well taken care of, a superb example of a well kept old school Toyota T100. We looked for many months to find this epic score.
4x Falken Wildpeak AT3 265, 10 ply sidewall 123S load rating tires in May 2023, 55,000 mile warranty (paid $1350)
Timbren 2000lbs Sealed Airbag system installed (March 2022)
Skyjacker Hydro 7000 rear shocks fitted (March2022)
2" Lift front & Rear
1.5" Wheel spacers all round
16" Toyota Alloy Rims fitted
New power steering pump (May 2023)
New steering gearbox ($840 of work, with receipts, May 2023)
Full synthetic oil change (August 2023) Changed every 3k.
Tracking & balance (May 2023)
Paperwork for brand new radiator and coolant flush
Chassis stripped & re-painted February 2022
Front brakes, rotors and calipers replaced at 153k miles ($630 of work, with receipts)
Water pump, timing belt kit, head gasket, Knock sensors, spark plugs, oil cooler seal, front crank seal, thermostat replaced at 162k miles ($1900 of work, with receipts)
New radiator clamps and cap ($325 of work, with receipts)
Super clean frame and body work with no rust. Kept in extremely good condition throughout.
2" rear Hitch ( Bike rack in photos not included)
2x Bike Axle mounts 15mmx 100 or 110 Boost, or 9mm axle conversions up high on the box, access by the ladder/roof
Upgraded seats to a Tundra Bench Seat with middle cup holder/storage or 3rd front seat
Averages 10-12 mpg
Notes:
We hoisted the box on and off with a mechanical hoist in a workshop, if you don't have this available, it would be easy to fit the camper shell legs to the exterior to get it on and off.
We used the truck always with the camper shell on, and spent most of our time travelling in the truck.
Starts cold without issue 10/10, rarely struggles with a hot start, we've had it worked on and replaced parts within the fuel breather system. Does not affect daily use, can be used everyday without issue.
Flatbed is currently the metal frame, no wood decking
Emergency brake works at about 50% capacity, easy fix but we haven't had a chance to get it done.
Burns a little bit of oil, but nothing out of the ordinary for a 30 year old truck.
If you're looking to go fast, this rig is not for you. Driven well it does 65mph all day on the highway, but you will be doing 40mph up the big steep long hills in 3rd gear.
Conclusion:
This is your chance to buy an epic, trustworthy Toyota, turn key, ready to go, overland style adventure rig with all the bells and whistles. We built this rig to drive down through Baja but never made the time.
We are currently working near Sierraville, 1 hour north of Truckee on Hwy 89. We make visits to San Fran every now and then, and in Salt Lake, Utah in the fall/Winter time.
We can be available with the truck for viewings until mid september.
This is still our daily driver so mileage will steadily increase.
Priced to sell at $32,000, we are open to best offers. This is a super unique and rare truck / camper build, we are not in a rush to let it go.
Let us know if you have any questions.
Cheers, Caroline and Jack
Howdy
The Toyota T100 never was and never will be a 3/4 ton pickup.
I have owned one since 1997.
David Graves
Thanks Frank! We love but are sad to see it go. Really hoping to find the right person here.
