Does your Bobcat have separate charging and light connections? If so, it might be a good time to consolidate them into a single connector. On my Cougar, I had it built with a single line to a 7pin bed connection that I use with my hard side. Monte has a great point about the smart alternator.nr541 said:I have jack extensions for the front, which Marty said should be fine. Any issues with swapping the electrical? Or was it pretty straight forward?
That looks great! I’m a newbie to wander. I have a 2013 tundra crewmax im thinking of try to fit a used bobcat on. Curious what it did to the gas mileage?Finally got the bobcat on the Tundra! And we’re loving the new look. Ended up making a box with 2x4s and plywood. The turnbuckles obviously weren’t long enough and I couldn’t seem to find what I needed at Home Depot. So I got steel caribeaners and eye bolts to help secure. Seems to work well so far but anyone else have any input?
