Flatbed build, clearance between truck and camper? Alaskan and 2018 Silverado
Shawn S
Aug 27, 2021
Posts
14
The pickup is a 2018 Silverado 3500 8' pickup bed, duramax. Camper is a 2001 10' CO Alaskan. I removed the pickup bed and will be installing a flatbed.
I am mocking up my camper so I can get going on my flatbed build. The wood is only for mockup purposes, the flatbed is not going to be made out of wood.
This is as tight as I can get it, now I need to figure out how much I need to back it off.
This camper is sitting on a frame made of two 2x4's stacked, so as this sits it is 3" above the truck frame. I have about 1" between the camper and the back of the cab, 1" clearance to open the rear cab doors, and the closest point between the cab roof and the camper is 1/2".
What do you all think those clearances should be? For reference, the top rail on the factory bed sits 1" from the cab.
I am thinking of trying to stick to the 1" between the camper and the cab. Add another 1/2" between the frame and the camper to give me an 1" on the closet point between the camper and the cab.
If I go that route I would build a flatbed that would have my camper sitting 3 1/2" above the truck frame. I plan to add 1" sides to my flatbed that match the footprint of the camper, so the camper will "sit" in the flatbed and shouldn't slide around. Of course I will also mount the camper to the flatbed. I mention the sides so you know that the camper shouldn't slide around, and hit the truck cab.
Roof clearance
My 2¢… give yourself a little more clearance between the cab top and cab over. I have had a camper touch the cab top when hitting a bunch of rollers at highway speed. I’m not sure if it was bed/frame flex, or tie down issues, but I didn’t like it.
Wandering Sagebrush, how much clearance did you have when it was hitting? What kind of truck was it?
Although, more clearance also has problems in the form of weird acoustic effects (howling, rumbling) due to turbulence/resonance. This especially happens in strong sidewinds at highway speeds. Some people put a pool noodle or other soft spacer in there to eliminate resonance.
I figured I would report back in case anyone else finds this thread and has similar questions. I ended up bumping the camper up another 1/2", so the closest point to the cab is about 1 1/2". We have gone on two 1500 mile trips, one into both the north and south end of the Big Horns, and another to Rocky Mountain National Park and we didn't have any issues on either. We ventured off the highway on both trips, and things went quite well. We averaged about 15 mpgs (diesel) at a top speed of 75-76ish mph. I think the low camper helps mpgs a little.
Are you happy with your flatbed build? Would love to see what you came up with, as I am thinking maybe doing a flatbed also.
