Old Crow
Searching....
I'm probably not the only one to have gotten an unpleasant surprise when opening the slide valve on a Thetford porta-potty.
The lower tank is a sealed compartment so changes in elevation can cause pressure buildup inside the tank. Open the slide at the wrong time and distressing things will happen. Curse words will flow freely.
I mention this as I made a mistake last Fall.
After dumping and cleaning the potty, I added deodorant and water. Typically, I have the slide closed so I can use that little well above it to measure the deodorant. Then I add water and let the mix down into the tank.
This time, though, I opened the slide and put the water in and closed it to measure the deodorant. Somehow, I got distracted and forgot to let the deodorant down into the tank.
At this point I have to mention that I was also trying a new deodorant. It turns out that deodorant not only has a very strong smell but it also stains anything it touches a bright blue.
You can imagine where I'm going with this.
On the next toilet use, I slid out the toilet and -- thankfully--- thought to pull out the slide before opening the lid. That blew deodorant all over the toilet bowl and the inside of the lid. It even blew some of it past the edge of the lid. It looked like something out of a horror movie.
I grabbed paper towels and mopped up as fast as I could. I probably should have stepped away to let the air settle as my eyes were burning as I worked.
The worst part was the staining. That blue chemical somehow got into the plastic and just wouldn't come out for the longest time. I saw blue staining for days.
I shudder to think what would have happened if I would have opened the lid and seen the deodorant and had been over it as I opened the slide.
I added this to the potty lid to remind me to think whether the potty had changed elevation before opening the slide. But since the deodorant event, I always open the slide before opening the lid.
