Excellent work, wuck, and great problem solving!
#51
Posted 14 November 2016 - 06:44 PM
2003 Ford Ranger FX4 Level II 2013 ATC Bobcat SE "And in the end, it's not the years in your life that count. It's the life in your years."- Abraham Lincoln http://ski3pin.blogspot.com/
#52
Posted 20 November 2016 - 08:59 PM
Thank You Sir!
#53
Posted 20 November 2016 - 09:26 PM
I found some better pictures of the original awning mount to share before wrapping up the new mounting.
Here are those screw/rivet pairs holding the awning on the camper, and the upper rail.
And some of the damage caused by those screws/rivets:
Somehow, all that water and gunk were getting past the railing and washing over the mounting rivets, some ending up inside the wall. Remember, the gray trim strip is a separate piece, so there are two seams compromised here.
And here the bend in the casing as it passes over the trim can be seen
There was a similar bend at the rear of the casing.
#54
Posted 20 November 2016 - 09:57 PM
In order to space the awning away from the trim and seams, I first installed spacers under the siding on top of the mounting rivnuts.
Now we'll skip ahead a few weeks, after the new aluminum skin (siding) and trim were applied. I drilled a small pilot hole through from the inside using the rivnuts for location. Moving outside, the larger clearance hole was cut, the unthreaded portion of the rivnut perfectly centering the drill bit once it began cutting into the skin. I used an additional set of plastic spacers between the awning and siding to keep it from crushing the seams or the trim.
Along with a bracket to add support out front where the Fiamma engineers clearly intended
I cleaned up the awning, evicting the tenants and painted the UV damaged end caps.
Old mounting holes alongside the new button head screw inside the casing.
#55
Posted 20 November 2016 - 10:08 PM
#56
Posted 21 November 2016 - 12:22 AM
Poky
1999 F250 crew cab SRW, 7.3 Powerstroke TD
1981 Grandby shortened to a Hawk
Build thread / https://www.wanderth...by-into-a-hawk/
#57
Posted 31 August 2020 - 02:11 AM
#58
Posted 04 September 2020 - 10:44 PM
I have the same year model Hawk with the fridge at the front. These were called X models and i believe there were less than 20 of this particular model built. Stan Kennedy might know more but, i do know the numbers were low.
#59
Posted 05 September 2020 - 07:16 AM
I have talked to Stan Kennedy a time or two, he told me there were production issues involved with that layout but didn't elaborate.
Thanks for the comments guys, happy I could help out with the bedboard, I had the best help from Marty at ATC for mine.
#60
Posted 05 September 2020 - 02:52 PM
Nice solution! I have been trying to come up with a hanging cleat idea so I could quickly remove the awning when not needed or move to the drivers side. I have an ‘04 X model it seems, I didn’t know it was rare as hens teeth!
Also tagged with one or more of these keywords: FWC, Hawk, mods
Trucks, Campers, Gear Forums →
Gear Exchange →
2011 Four Wheel Hawk in excellent conditionStarted by surfstrongfit , 20 Apr 2024 hawk, four wheel camper |
Gear Exchange →
2011 FWC Kestrel $16,800 Akron, OHStarted by Smorgash , 15 Apr 2024 Kestrel, FWC, Four Wheel Camper and 1 more... |
Gear Exchange →
2009 Eagle Four Wheel Camper Madison WisconsinStarted by WiscoK , 10 Apr 2024 truck camper, FWC |
Gear Exchange →
FS: 2023 FWC Project M for 5.5' Full Size Beds - $14,000 - Colchester, VTStarted by danruss , 06 Apr 2024 fwc, project m, tundra, 5.5, 2023 |
Gear Exchange →
For Sale: upgraded 2001 FWC EagleStarted by Wildcat , 26 Feb 2024 FWC, Eagle |
