propane tank certification
29 replies to this topic
#21 craig333
craig333
    Riley's Human
  • 8,022 posts
  • LocationSacramento
Posted 09 May 2017 - 11:39 PM
Saw another article today. Seems the new rules are on hold while the gas association challenges the changes. Standby.
#22 Old Crow
Old Crow
    Searching....
  • 1,059 posts
  • LocationSouth Central PA
Posted 10 May 2017 - 01:07 PM
AmeriGas (Kalamazoo, MI) recertified my FULL 20# tank for $5.
Only took about 5 minutes, that includes getting out of my truck, going inside to ask, back in the truck to a back building, gave tank to guy, me look around at the old giant propane tanks, guy gave me back the tank, back in the truck, drive back to the front building, paying $5, back in the truck. :-)
Mike
Thanks for posting, Mike.
Your post prompted me to make another call to the Suburban Propane location here in PA where I was previously told (on two different occasions) the tank would have to be purged.  I told the office person I had seen a post saying a purge hadn't been done on someone else's tank in another state and asked if she could ask the re-certifications tech why the purge is done at their location, i.e., what does the tech do that requires a purge.  She returned with (today's) answer-- a purge is only needed to fill a new tank, not for a re-certification.
She also said the re-certification is an external visual inspection plus their tech uses a soapy solution to check the valve and gauge for leaks.
'01 FWC Hawk shell on a '13 Tundra Double-Cab  + '19 Ford Transit van with Quigley 4x4 option
#23 flinchlock
flinchlock
  • 424 posts
  • LocationKalamazoo, MI
Posted 11 May 2017 - 10:43 AM
I forgot to mention that "my guy" also said it was just a visual inspection.  :huh:
Mike
'08 ATC Cougar (built 06/16/08)
# of nights in camper: '08=15, '12=21,'13=16, '14=10, '15=52, '16=11, '17=20 (equals 145)
#24 K6ON
K6ON
    Old & Soft
  • 1,173 posts
  • LocationSacramento, CA
Posted 11 May 2017 - 02:37 PM
My camper is 21 years old as is the propane tank. The tank has been "inspected" and tagged twice, the last time,10 days ago.  The
"inspection" consisted of checking the tank for surface rust and a little soapy water on the valve.  $5.00 later it has a new tag and is good to go.
  • 1
2007 Dodge 2500 5.9 CTD QC 4X4, *1996 FWC/ATC hybrid* *2021.5 GeoPro 19FBS*  "If you can read this, Thank a Teacher.  Because you read this in English, Thank a Vet."
#25 OSUFlyer
OSUFlyer
  • 71 posts
  • LocationWahkiakum County, WA
Posted 11 May 2017 - 07:51 PM
Active Enterprises, Long Beach Wa. $5 or $10?
Similar as above, quickly inspected, recertified and attached a tag on my horizontal propane tank before filling it.
1997 OBS Ford 7.3 DSL 4x4
1985 Four Wheel Keystone
#26 MarkBC
MarkBC
    The Weatherman
  • Site Team
  • 6,600 posts
  • LocationBend, Oregon
Posted 25 September 2019 - 09:28 PM
...In Central Oregon I know that Ferrellgas will requalify a tank for $20.
Two years later, it's still true.
I just got my 2005 vintage, original equipment horizontal propane tank recertified/requalified today at Ferrellgas . The guy did a leak test -- with soapy/detergent liquid.  He also did a visual inspection. It was the inspection that raised a question.  There was a significant rust spot on the side...but he still passed it.  He advised me to sand out the rust and repaint it, which I'll do.
Now all set for 5 years.
  • 1
#27 ckent323
ckent323
  • 1,227 posts
  • LocationSolvang, CA
Posted 25 September 2019 - 11:10 PM
I had a tank recertified in August in California. Similar to K6ON experience: The "inspection" consisted of checking the tank for surface rust and a little soapy water on the valve. $5.00 later it has a new tag and is good to go.
#28 Old Crow
Old Crow
    Searching....
  • 1,059 posts
Posted 04 October 2019 - 05:32 PM
     The recent posts in this thread reminded me to get my Hawk's Manchester horizontal 20-pounder re-certified and filled for a trip coming up this weekend.
I had looked into it some time ago and called several big-name propane suppliers in my area. They told me I had to take it to a propane dealer almost an hour away and had to leave it as they don't do walk-in services.    But this time I called my local Ace Hardware (knowing they can't do re-certifications) and asked where they refer people who need a re-certification.  It turns out there's a fuel-oil dealer nearby who also has a propane fill station in the back and the certified techs who can do what I need --- and it's only five minutes from my house.
When I called, the office lady told me she'd check for a tech when I arrived and if there's one available it could be done while I waited.  If not, I'd have to leave the tank.  The Ace guy had warned me I'd also have to have a fill done there but I wanted to have a full tank for this trip anyway so that wasn't an issue for me.
There was indeed a tech available when I walked in and he did the re-certification and fill right away.  He did a visual check but did not check the valve with soapy solution.
My bill for the re-certification and fill was $15.  A fill at the local Ace is $12.
Tare weight of my tank is 21.0 pounds (according to the stamped-in markings on the tank collar).  After the fill the tank weighed 39 pounds, so that's 18 pounds of propane, not the expected 20 pounds.  I spoke to the tech about that and he said my tank's OPD (overfill protection device) cut off the fill a bit early.  (I had noticed him react with an "OK, then" type of reaction toward the end of the fill and didn't quite understand why at the time so I think that's indeed the case).
#29 PJorgen
PJorgen
  • 178 posts
  • LocationNorthern Nevada
Posted 06 October 2019 - 06:15 PM
Propane tanks are supposed to be filled to only 80% of capacity.  Here's something from Amerigas on that topic:
https://www.amerigas...rcent-fill-rule
We have a 500 gal tank for our home and the delivery guy is adamant about only filling it to 400 gal.  In fact, the gauge has a big red mark at 80%.
Not all propane dealers know or follow this rule.  One time I had the tanks on my FWC filled early one cool morning in Tonopah.  Stopped later that warm afternoon to set up camp.  Went around to the back of the FWC and could smell propane very strongly!  The overpressure valve was hissing away propane.  Obviously that dealer didn't follow the 80% rule.
2014 Hawk, Silver Spur exterior on a 2012 GMC 2500HD 4x4.
#30 larryqp
larryqp
  • 299 posts
  • LocationFull-time RVer, anywhere USA
Posted 07 October 2019 - 12:19 PM
You are correct on the 80% rule, your OPD should shut down the fill at 80%, so if its not doing its job, it may be time to replace the OPD.
2016 F150, FX4, XLT super cab
2019 FWC Hawk Shell
2009 Ford Ranger 4x4, XLT, Supercab total loss on 7/30/19
2014 FWC Shell total loss on 7/30/19
