roof lifting helper shocks thingys
418 replies to this topic
#361 pvstoy
pvstoy
  • 2,772 posts
  • LocationCarson City, NV
Posted 25 March 2018 - 05:05 PM
Hawk owners or even Grandby.  I'm planning on two 180 watt ridge solar panels on the roof mounted between the two vents in the middle of the roof.  Weight will be around 55 pounds.
Who has done similar and what pound weight struts are you using?
Right now there is 20 pounders front and back and the few times I have poped up it seems that is not enough to assist.  What experience do you have having the weight in the center of the roof?
Thanks....
Patrick
2015 FWC Hawk Flatbed
#362 Outnabout
Outnabout
  • 280 posts
Posted 26 March 2018 - 03:41 AM
I have a 160 watt panel between the vents but more close to the forward vent on my Grandby. I use 40lbs in the front and 30lbs in the back. It still takes some umpf to get the front up. Easier when I raise slower.
#363 pvstoy
pvstoy
  • 2,772 posts
Posted 27 March 2018 - 04:06 PM
Factory tells me that I should have 20 rear and 40 front from factory.  Need to check front again but the paint is wearing off to make sure it was 20 or?   They suggested with 55 pounds for solar in the middle of the roof between roof vents to have 40 rear and 60 front.
Patrick
#364 Vic Harder
Vic Harder
    Doctor Electric
  • Site Team
  • 4,968 posts
  • LocationCalgary, Alberta
Posted 27 March 2018 - 04:27 PM
I have a 265W panel on the very front of my Hawk (no vent).  40# front, 30# rear.  This makes for a "balanced" roof, meaning it requires a slight tug to get down, and still needs a push to get started, but will not "lift" on it's own either.
#365 pvstoy
pvstoy
  • 2,772 posts
Posted 30 March 2018 - 02:16 AM
Thanks Vic. I will be at factory next week and will discuss my set up.
Patrick
#366 Advmoto18
Advmoto18
  • 1,083 posts
  • LocationCoastal Low Country, SC
Posted 09 April 2018 - 07:00 PM
Vic
Do you have the P/N for the rear 30# strut?
Thanks!
Bill
South Carolina Low Country.
#367 Vic Harder
Vic Harder
    Doctor Electric
  • Site Team
  • 4,968 posts
Posted 09 April 2018 - 07:52 PM
Vic
Thanks!
Bill
Front and rear are same size/lenght.
30# - C16-22241
40# - C16-15952
Note, this does not include the brackets.  I got Stainless Steel ones from West Marine, part number 1891.
#368 Advmoto18
Advmoto18
  • 1,083 posts
Posted 09 April 2018 - 08:43 PM
30# - C16-22241
40# - C16-15952
Thanks!
Did you use self tapping screws through the skin directly into the camper's frame tubing?
Thx again!
#369 Vic Harder
Vic Harder
    Doctor Electric
  • Site Team
  • 4,968 posts
Posted 09 April 2018 - 08:58 PM
These are the instructions I used:
http://www.wanderthe...r-too/?p=148007
I used existing holes from the rain gutter I had on my Hawk, and drilled a couple of small pilot holes.  Then just used galvanized 3/4" #8 wood/metal screws to attach the plates.  And Dicor sealant in the holes and on the screw once I was happy with the installation/operation of the lift.
Pilot hole
pilot hole
Mount like so
or that way?
Mounted
IMG 0706
Installed
upper mount
Edited by Vic Harder, 09 April 2018 - 08:59 PM.
#370 Advmoto18
Advmoto18
  • 1,083 posts
Posted 10 April 2018 - 12:11 AM
Thanks Vic!
I just ordered the C16-22241 from Suspa.  3-4 week lead time.  Not an issue.
I have the factory inside struts at the forward bulkhead which easily lift the front of the camper.  The wife is having great difficulty (impossible really) raising the rear.  I was leaning towards the 40# for the rear, but that seems to be a bit much even with the solar panel on the roof.  30# in the rear seems perfect as you and others have stated.
Thanks for the "how to" pics!
Bill
