Camper Charging Issues
#31
Posted 15 August 2015 - 02:14 PM
https://gregsmarinewiresupply.com/Zen/
#32
Posted 15 August 2015 - 02:21 PM
I am haunted by waters
#33
Posted 15 August 2015 - 02:53 PM
I picked up the wire and connector at our local princess auto. It was sized for the 4 gauge wire. I believe it is rated to 125 amps. The wire is welding cable, which may not be quite as resistant as the marine grade battery wire but is priced well and should do the job. Also, there aren't a lot of marine shops here in Calgary . It came in precut lengths of 25ft, so we bought 2 packs (one for hot and one for ground). We used red and black heat shrink tubing at the connectors to identify which was which.
I wouldn't have been able to fit #2 or #0 gauge wire into the camper and back to the battery without cutting a larger access hole into the camper and some of the cabinetry (which I was trying to avoid). The #4 gauge worked great.
Edited by Ronanmd1, 15 August 2015 - 03:00 PM.
#34
Posted 15 August 2015 - 03:02 PM
Thanks
Edited by Ethergore, 15 August 2015 - 03:05 PM.
#35
Posted 15 August 2015 - 03:07 PM
http://www.knukoncep...wire/kca-kable/
Edited by Ethergore, 15 August 2015 - 03:11 PM.
#36
Posted 15 August 2015 - 03:15 PM
Ethergore - I can't get that link to open
#37
Posted 15 August 2015 - 03:55 PM
I bought the Anderson 120 connectors from my local Grainger, but they can be had online as well. One vendor:
http://www.powerwerx...0-amp.html#desc
The 6 gauge wire that I used is "duplex wire" from West Marine. Not the least expensive option, but it fit my needs very well.
http://www.westmarin...009_274_003_002
My local Powerstride Battery store sells welding cable and related terminals, adhesive lined heat shrink, etc. in a range of sizes.
Where does that road go?
#38
Posted 15 August 2015 - 05:19 PM
I saw a recent reference to WayTek Wire, that appears to have been edited. They have a great woven wire loom that I use on my boat, and will probably use on the camper. It does a great job of cleaning up exposed wire runs, plus the protection needed in areas that might get light abrasion.
#39
Posted 15 August 2015 - 05:47 PM
#40
Posted 15 August 2015 - 09:05 PM
Ethergore - I bought the Marineco plug from amazon http://smile.amazon....ailpage_o05_s00 and yes it was expensive but it fit in the hole perfectly that was from the original installation by Four Wheel Camper. This plug is only rated for 40 Amps, I was getting over that but only a very short time.
I used 6 gauge wire bought from Lowe's. I used 6 gauge wire as that is what the Sure Power Separator installation instructions called for. http://www.fourwh.co...parator1315.pdf Also I did run the wire in a corrugated loom. 25 feet of wire was barely enough wire for my full size double cab truck (this also included what was needed in the camper). The 6 gauge wire allowed me to use Maxi Fuse holders http://www.delcity.n....jsp?item=78515 already wired into 6 gauge wire. These fuse holders wired directly to the batteries on both ends, you must have a fuse or circuit breaker as close to the batteries as possible. I used a 60 Amp fuses bought at Napa as I saw that 55Amps with the jumper cables. I have been thinking that I'd like to try a 50 Amp or 40 Amp. I think I could get away with the 40.
I am so glad that I bought the Harbor Freight hydraulic wire crimping tool (another $50) finding the proper 6 gauge wire terminals were the hardest parts for me to find.
Edited by DavidO, 15 August 2015 - 09:07 PM.
