Hi Tim
Hay good job there, like the thought that you can retrieve items either inside or out.
Russ
Thanks Russ! The first test run of it this past weekend was a success!
Posted 23 October 2018 - 08:10 PM
Hi Tim
Russ
My youtube channel about my Four Wheel Camper - https://www.youtube.com/c/timmorrissey
All about my camper - https://www.tgmorrissey.com/camper
Item I used in my build- http://bit.ly/TGMorrisseyParts
Posted 29 October 2018 - 03:32 PM
Another sewing project. Again with plenty of help! My siblings and wife lent a hand for a quick weekend work of sewing curtains and making cushions for the camper. I really enjoyed this project. A lot less stress than the canvas sew job.
Posted 03 November 2018 - 02:04 PM
Some good, some bad. I made a new table to match my countertop. The table is super functional and looks almost perfect, except for the edge banding. Used Rockler edge banding and it is coming apart already! Any experience with this stuff?
Posted 03 November 2018 - 10:43 PM
I would guess one or a combination of these possible causes:
1. Iron was not hot enough or you moved to quickly to melt the glue sufficiently.
2. Insufficient pressure on the veneer once the glue was hot until it cooled.
3. Rough/uneven plywood edge preventing good contact by the adhesive.
4. Edge of veneer exposed to catching due to imprecise trimming. Usually want to trim the veneer at an angle down from the top and do a light sanding of the edge.
I have not had good experience with the iron-on product on things that are subject to traffic use such as your table top. Better luck with things usually out of harms way. I would recommend you use a thicker solid wood strip glued and tacked on instead, or a metal edge trim applied with glue and screws made for the purpose. Not as aesthetic maybe but probably more functional.
Good luck. Fun to see you restoring the old camper and enjoying using it. I enjoy watching your videos. Thanks for posting them.
Posted 04 November 2018 - 02:40 PM
Posted 04 November 2018 - 03:26 PM
Posted 04 November 2018 - 10:02 PM
Thanks for all the suggestions. Do you have a product in mind for the metal edge trim that might be more up for the task? Thanks - Tim
Posted 04 November 2018 - 10:07 PM
Tim, awesome job.What made you decide to use a buddy heater rather than an RV furnace? Also I was wondering if you have made a charging system for your house battery, I've seen in your videos that you use solar to charge.
I got the buddy off craigslist for next to nothing and it works. I would prefer an RV furnace but they all run closer to 1k$ and I didn't want to make the investment. Maybe ill upgrade if I ever come across a good deal.
I just charge the battery with a garage battery charger that I picked up from the autoparts store. No alternate hook up or anything like that. I have plans for solar but am yet to execute on it. Since I have such a low power demand, just the led bulbs, my battery last incredibly long. I calculated it once, I think I could run all 8 of my bulbs for weeks or months off my deep cell. Once I get some usb ports and an inverter it will be a different story. That will probably happen in the winter/spring. Very little progress will be made on the camper till my kid is born and I finish my PhD. both expected Jan 19.
Hey I also wanted to ask if you think 1/2" conduit would be sturdy enough to use for the roof lifting mechanism.
Maybe? I would probably stick with the 3/4, what do you think you would gain from going 1/2"? I would guess not much a significant weight save.
Posted 05 November 2018 - 02:11 AM
Haven't used any lately. Mostly use a wood edge. Maybe you could get some ideas here: http://heffrons.com/retro/banding.html
Posted 06 November 2018 - 02:20 AM
1999 F250 crew cab SRW, 7.3 Powerstroke TD
1981 Grandby shortened to a Hawk
Build thread / https://www.wanderth...by-into-a-hawk/
