Looking at late 1990's palomino for 4.0 V6 Tacoma lots of questions!
#1
Posted 21 July 2016 - 09:26 PM
#2
Posted 21 July 2016 - 11:40 PM
#3
Posted 21 July 2016 - 11:44 PM
#4
Posted 22 July 2016 - 11:45 PM
Procedure to insert photos into Forum Wander The West site
1. Open Two WTW windows.
2. First window go to Post and select edit
3. Second Window Go to YOUR “My Gallery” on your profile.
4. Upload pictures to WTW Gallery.
5. Click on “Thumbnails”
6. Click on “photo” to insert (enlarges it)
7. Right click on image. Select “Direct Link to this image”
8. Right click again . Select “copy link URL”
9. Toggle to First window. Place cursor location photo to be located and
Left click “Image” icon on Tool bar.
10. Paste URL into open field. Click Ok
11. Done successfully.
#5
Posted 23 July 2016 - 12:20 AM
Weight is the issue with a mid size truck.
How much does the Palomino weigh empty?
Whatever it weighs add 350 pounds for food, water, gear, etc plus people?
Contact Palomino to get the weight with the options you have (3 way fridge, etc, etc). Find out what type of frame it has wood - heavy? or aluminum"
The GVWR of the Tacoma is 5500 pounds. Our 2013 4.0 V6 without the tailgate and half tank gas no people weighs 4100 pounds. The axles are rated at 5800 pounds and 10 ply tires rated at 6,000 pounds.
When I go to the desert for a week, Our rig weighs 6100 pounds loaded with a full tank of fuel and one person. The reason the factory gross is 5500 pounds relates to the stopping ability of the brakes. We downshift the auto trans when going down off ramps using the transmission to help slow it down.
We really have to drive conservatively when we tow the Samurai because we don't use its brakes. We could if we paid about $ 800 for the braking device. Hasn't been an issue in the 3,000 plus miles we've towed it.
Edited by RC Pilot Jim, 23 July 2016 - 01:24 AM.
#6
Posted 23 July 2016 - 06:07 PM
#7
Posted 25 July 2016 - 02:23 AM
#8
Posted 27 July 2016 - 05:26 AM
#9
Posted 27 July 2016 - 05:41 AM
Www.torklift.com
Edited by Stan@FourWheel, 27 July 2016 - 05:42 AM.
Woodland, CA 95776
www.fourwh.com --- e-mail = stan@fourwh.com
#10
Posted 28 July 2016 - 10:48 PM
I use/used turnbuckles that attach to the 4 frame connected bolts in the newer Tacoma composite bed. I improvised some heavy duty rappel anchor type hangers for the 2 front turnbuckles as I surmised these were the most important. Had to drill out the hanger slightly for the as supplied Toyota bolts that seem to be around 7/16"
My Palomino has been mostly off the truck as I use it for work so wanted a set up that I could rig pretty quickly for weekend trips.
http://www.metoliusc...lt_hangers.html
The web site does not show the rap hangers that are fabricated from 1/4" plate stock.
