Rear Steps
37 replies to this topic
#31 cwdtmmrs
cwdtmmrs
  • 610 posts
Posted 01 May 2017 - 05:13 PM
I modified the Brophy step to flip up and over when not in use and held in place with a spring loaded catch. The original idea was from Bosque Bill. I had a scissors style step, but you must be on very level ground for them to work and they will dig into the dirt as well.
cwd
CWDT
#32 Wandering Sagebrush
Wandering Sagebrush
    Free Range Human
  • Site Team
  • 10,593 posts
  • LocationNortheast Oregon
Posted 01 May 2017 - 08:42 PM
cwd
Nice work!
I am haunted by waters
#33 rodt
rodt
  • PipPip
  • 13 posts
  • LocationNebraska
Posted 02 May 2017 - 04:11 AM
Those Brophy steps are spot on. Can you discuss the up fit a bit more?
#34 hebegebe
hebegebe
  • 234 posts
  • LocationLA and San Diego
Posted 02 May 2017 - 02:18 PM
cwd
I have the 4 step brophy its important to level or shim the lower step on uneven ground ask me how I know. The top of the bracket popped up a 1/4" past the door one nite and there was no way to open it. glad there wasn't video of me escaping through the emergency exit in my skivies!
#35 Esus
Esus
  • 118 posts
Posted 02 May 2017 - 02:40 PM
cwd
What did you have to modify? I like that this solution looks to provide more clearance in the rear than many others.
2015 Chevy Colorado, 2015 FWC Fleet
#36 cwdtmmrs
cwdtmmrs
  • 610 posts
Posted 02 May 2017 - 03:42 PM
I was afraid people would ask. Not an easy modification. Start with the Brophy 2 step. Cut the bottom step and bracket off and then cut the step off of the removed bracket. Discard the removed bracket. Figure needed geometry and bend new lower bracket from 2" x 1/2" steel and weld tube on for hinge pin. Weld removed step onto new bracket. I wanted to use step in up or down position so I made another diamond plate and welded it to the original step, kinda like a tube. Weld tabs onto receiver tube for hinge pin. Weld modified spring loaded pin gate catch on upper bracket and mating tab onto lower bracket for pin to lock. Hinge pin is 1/2 SS bolt with nylock nut. Install rubber bumpers onto upper step for no clanging when folded  Powder coat with semi gloss black wrinkle finish. Attach with locking anti rattle hitch pin. There you have it!
These steps are the perfect height for my rig and when fold the license plate is still fully visible. They are rock solid with the anti-rattle hitch pin with zero rocking side-to side.
I couldn't find anything like this available and thought about producing them commercially, but didn't think the demand would be that great. Wouldn't be inexpensive either.
cwd
Edited by cwdtmmrs, 02 May 2017 - 03:54 PM.
CWDT
#37 Esus
Esus
  • 118 posts
Posted 02 May 2017 - 08:19 PM
Nice work! Wish I had the tools and skills to make that happen.
#38 Josh41
Josh41
  • 152 posts
  • LocationMassachusetts
Posted 02 May 2017 - 09:38 PM
Dagwood,
How did you mount your GlowSteps? The Torklift site shows them drilling holes and bolting on a mounting bracket. My Nissan Frontier has a step built into the bumper and it doesn't look like it would work.
Thanks
Mike
Mike,
The Fleet will hang just to the end of the bumper so the step in the bumper will be under the camper and not too useful.
Josh
Nissan Frontier 2016 CC LWB, 2" lift, tires, airbags and other stuff
FWC Fleet
Summers Off
