Winter Camping Advice
#21
Posted 07 October 2016 - 06:28 PM
I love this site! So many brains working together!!! Thanks guys!
#22
Posted 07 October 2016 - 06:34 PM
I agree, a rear ski rack would be ideal, just no way to easily attach it. And take off angles may be an issue.
#23
Posted 07 October 2016 - 09:14 PM
Nice ladder
#24
Posted 07 October 2016 - 10:13 PM
So is the Grandby C1 or A1?
Jugging the roof! Pure genius!!! Plus, many dirtbag points as an added bonus. What do you anchor to? How did you access other areas of the roof.
C-1, no nailing on my rig!
C1, solidly placed sky hook
My setup: web ladder attached to an appropriate length of webbing with a sky hook on the end. Sky hook has been filed to a point. Webbing is thrown over the roof of the camper and hooked onto the underside of the overhang. I have two attachment points for the hook on the webbing: roof up, roof down. Assembly can be moved forward or backward to access different areas of the roof from either side. Oh, and the underside of my overhang is painted plywood, so the sky hook digging in a little bit doesn't bother me = bombproof. If your underside is covered with aluminum sheeting you might want to use a suction cup or some such instead of a point on the hook.
I have thought about adding fixed anchors to the underside of the overhang: T-nuts and bolts, since I tend to place the ladder in the same places consistently. Might do that while I have the camper in the shop this winter for lift panel replacement.
I like it because it stores in a nice, small package.
If you have an old length of rope one could use that and jug your way up, for more style points.
jim
#25
Posted 07 October 2016 - 10:20 PM
Unfortunately that wasn't on the forum, it was a camper I saw in person last year... and it seems I have no pictures. Which is stupid, because that owner had a lot of good ideas.Seth, any chance you can find the side rack thread?...
It wasn't off the jack brackets, though. The mount was more like 3 pieces of 1.5" x 0.125" steel stock that were though-bolted under the window of the camper, behind the back of the couch. Imagine shoving a 12" ruler between your camper and the truck bed rail. From there he'd welded up a basket sized for a couple pairs of skis. Then rust-proofed it with powder coating - that's something you prep and then sub out to a specialty shop. Or, maybe you'd need to go out to a fab shop for all of it.
A rear rack is a bit of a head scratcher. Depending on how your camper sits on your truck, imagine a tray on the rear bumper, maybe 14" wide, 4" deep, 6" tall. That's a tray with 6" sides that you drop the back end of your skis into. An FWC dealer can (easily?) get the metal-biting equivalent of a wood screw into the framework of your camper's back wall - that's how your jack brackets are attached. This kind of screw:
http://shop.advancea...90_pri_larg.jpg
The question would then be how to fabricate and fasten some bracket, using that kind of screw into the camper's aluminum frame, with a few inches of offset, so your ski tips clear the back wall/roof, a bracket that you could attach a yakima or thule rack to... ???
#26
How does it feel up there with the roof up?
I think if I went to the turnbuckle attachment, I could downgrade to A0...I am getting older, after all.
#27
Posted 07 October 2016 - 10:24 PM
I think Bread has a great idea, but don't know where to get one made.
http://www.wanderthe...27-breads-mods/
The purple one third frame down.
#28
Posted 07 October 2016 - 10:27 PM
Just need some snow!!!
#29
Posted 07 October 2016 - 10:30 PM
#30
Posted 07 October 2016 - 10:36 PM
Fixed anchors makes it A, yes? Always referred to C as clean (cams/nuts)
Sounds like a great idea, time to dig out the aid gear.
Off Road Utility Trailer
Not enough time to go exploring.
