For a few years, I've had a package of the pictured material (Ultra Touch Radiant Barrier) laying around my shop. I think I bought it to use as replacement floor liner for my 4runner, then went another direction. Anyway, after reading all about Reflectix on the boards here, I went to HD to check it out. Kinda cool stuff, and I'll probably use some for compartment lining, but really, it strikes me as fancy bubble wrap. This Ultra Touch is 1/2" thick cotton "jute", covered with a foil barrier on one side.
I decided to use it as an Arctic liner, so I cut the 4' x 6' piece I had in half, taped the edges with aluminum foil ducting tape (Nashua), and put a couple strips of 2" heavy duty stick on Velcro to attach it to the existing Velcro on the inside of my soft sides. It's pretty much an even 24" vertical measurement, so cutting it half created no waste material. Looks like it should work well, with the jute toward the wall, and the foil toward the living space, it should do a good job of insulating out the cold transfer through the soft side, and reflect any heat generated inside the camper.
After, I made the first panel, I realized I should have "ripped" the piece in the 6' direction, and then I would've had two 2' x 6' panels, which would've completely covered once side wall of my Cougar camper. So.... I decided to get some more material, and use the stuff I had as a mattress insulator/condensation inhibitor, and I ordered a new roll of the same stuff only its 4' x 24' long, which means I can make 4 panels that will cover both walls, and can be stored under the mattress when not in use, and provide me with a little more padding.
I've made no provision for window use because my thinking is if I need the liner, I don't need the windows open. I'm of the the minimalist mentality, having made the move to this camper from a Snug Top shell, so the functionality of this works well for me.
Anyway, an FYI for anyone interested....
Edited by wcorbett, 07 February 2017 - 04:02 AM.
