#1
Posted 05 March 2017 - 05:14 AM
Thanks!
#2
Posted 05 March 2017 - 07:59 PM
If you look at the usd campers they sometimes have on their site they say that the previous roofs required yearly maintenance..
Eddie
KO4CPL
#3
Posted 05 March 2017 - 10:40 PM
I believe in 05 they were still the rubber roofs that needed annual maintenance if its original. Only reason I mention that is Hallmark regularly upgrades older campers with the new fiberglass roof and new canvas - about $5k if I recall. It would be worth getting a picture of the roof of the unit for sale - depending on the sale you might get a heck of a deal if its already been upgraded.
"I took the road less traveled. Now I don't know where I am"
2014 Dodge Ram 3500 diesel & Hallmark Everest. (Former Rig - 99 Ram 2500/ 2000 Sunlite Eagle pop-up)
#4
Posted 06 March 2017 - 06:06 AM
I think Smlobx and Vic are right that the roofs were rubber. Bill at Hallmark can confirm. Their phone number is on their web site. Be persistent, and don't bother writing, they rarely answer emails. I'm really happy we got an '08 with the composite roof. Leak free and looks like new still.
The other thing to know is that they didn't start installing the electric roof lift systems until some time (a year or two?) after the roofs were upgraded to composite. We've got an 08 with a composite roof and a hand-crank roof lift. The teeth of the crank/track are very soft metal and prone to stripping/cracking off if the crank is not fully inserted into the mechanism and held there firmly through the entire opening/closing process. It's a pain to deal with a damaged crank and track, but replacements can be bought.
Good luck! I really love Hallmark campers, if you can find an affordable deal on one with a composite roof and lift system in good shape I'd recommend it!
2006 Dodge Ram 2500 5.9L CTD short bed quad cab, 2008 Hallmark Guanella
#5
Posted 06 March 2017 - 08:18 PM
We have a 2005 Milner and yes, the roof is rubber. We did notice some stains on the headliner which indicated a water leak and had Andy at Hallmark check it out. He said the roof was solid and dry so we resealed it.
#6
Posted 09 March 2017 - 05:43 PM
Rubber roof, yes. Every year I have to get up on mine and make sure all of the seals around the vent, etc. are good. I've also had to use the 4" wide rubber roof tape around the entire outside edge and double on the corners to prevent leaks. Had one year that the tape leaked through and had water damage from rain every day in May event (set a record in KC that year). The water entered at the corners and ran into the side wall (top was down) and leaked through the sewn seem soaking the bunk. It was a mess to clean up. Also, those cheap covers from Amazon will help keep it dry, but only seem to last about 2 years. I wished I could afford to have the roof replaced, but it cost 4.2x what I paid for the whole camper :-(
Truck: 2006 Nissan Titan, PRG 6" lift, 315/70R117 Cooper STT Pro's, Firestone airbags
Camper: 2004 Hallmark Ute LTD, bobbed tail, expanded dinette bed
#7
Posted 11 March 2017 - 05:25 AM
Yeah, it's not cheap to have any significant modifications done at Hallmark. I believe Bill quoted us around $5K for a new lift system. I'll just replace the tracks myself and get a couple of new hand cranks if the teeth continue to wear down, and pat myself on the back for raising the roof using good old fashioned elbow grease.
Having a camper that started its life with a composite roof (08 or newer) is probably your best bet if you can afford it, but a used older Hallmark with roof replaced after 2008 may be significantly cheaper. Not sure if you can reliably inspect for water damage, though, without tearing into walls (which the seller would not likely allow).
We found ours by searching "All of Craigslist" rather than waiting for someone else to post an awesome deal on the used camper forum. It's worth looking there too, but the really good deals posted there tend to go fast. We considered ourselves fortunate that we only had to drive 450 miles to get ours.
