When you fill the 20 gallon water tank, will the filling also fill the hot water tank? Or once the water tank is filled, the FWC instructions say turn on one or both sink faucets and then turn on the water pump until the flow of water is smooth. Is this step what fills the hot water tank or does it fill when you fill the 20 gal. tank? This is a little confusing.
I may have been doing this wrong for the past 3 years and may now have paid the price of turning on the hot water switch with an empty or near empty hot water tank.
Hopefully Stan or someone else at FWC can clarify this.
As of now I have to replace the deformed hot water tank with a new tank. jd
