It certainly shouldn't drain that fast. It may not be getting a charge from the truck, especially if something drains it to the point the isolator kicks in. You probably don't have the IQ4 for the onboard charger. If you're going to plug it in at home you'll want that. We can walk you through using a dmm to find the drain if it comes to that. Pretty simple really. Do you own a voltmeter?
Battery Charge/Maintenance
#11
Posted 29 April 2017 - 03:31 PM
#12
Posted 29 April 2017 - 03:55 PM
The IOTA converter without an IQ4 puts out about 13.5volts. That is float voltage & not high enough for charging the battery. Fine for running DC accessories. With a jumper, it puts out about 14.2 volts; enough for charging but will overcharge the battery if left on, relying on you to manage the charging. IQ4 is only about $25 and just plugs into IOTA converting it to a smart charger.
#13
Posted 29 April 2017 - 05:12 PM
And since there is no solar, its a good idea get the battery a full charge on a regular basis which they won't get from the truck even if everything is working correctly.
Also, year and model of camper would help. Its unfortunate the factory didn't do a better job but they're slammed and it seemed to work when they checked it.
Hoping its the 3 way, that would explain it and its an easy fix but if its not measure the voltage across the battery with the main power switch off and with it on for starters.
#14
Posted 29 April 2017 - 08:39 PM
First welcome to the best site on the net for camping. There are many knowledgeable and friendly people here who will definitely help you.
I agree with others who believe that something is prematurely draining your battery. If you have a 3 way fridge I am betting that may be the culprit.
As far as maintaining your battery between trips it is actually more complicated than it should be (at least for me).
My manufacturer (Hallmark) reccomend these battery chargers which "exercise" the battery to keep it in tip top shape.
https://www.amazon.c...rds=noco genius
Keep us up to date!
Edited by smlobx, 29 April 2017 - 08:40 PM.
Eddie
KO4CPL
#15
Posted 29 April 2017 - 11:09 PM
+1 on the Genius. Great for keeping it topped up.
#16
Posted 30 April 2017 - 04:26 AM
I should also mention they make bigger, i.e. More amperage than than mine too. It works well none the less.
Edited by LuckyDan, 30 April 2017 - 04:29 AM.
Old, bum around in Ford and an even older FWC Grandby
New Mantra: "Everyday camping is just making up for lost time"
#17
Posted 30 April 2017 - 12:50 PM
I agree with the other poster... if it's draining that fast (and it's the camper battery), then it'd have to be the refrig. set on DC.
Boise, ID
2022 Chevy 3500 HD
2023 FWC Flatbed Hawk
#18
Posted 30 April 2017 - 03:39 PM
I agree check the fridge it draws 5 to 8 amps continuously andI will drain the battery in a couple hours. To monitor the battery all you need is a cheep plug-in voltage monitor for the 12V camper and truck sockets. You always want the voltage to be above 12V. If it is less the battery is mostly discharged. You can connect a small trickle charger like "Battery Tender" but they only supply milli-amps of current and take hours to recharge the battery with no load on the battery. When the battery is charging it voltage should increase at about 0.5 Volts the minute the charger is connected.
Here is a trouble shooting check list.
Make sure the fridge is off and most of the camper lights and fans are off. You may have to turn truck to AUX make sure everything fans radio ... are off.
1) Truck off both voltmeters should read the same between 12V and 12.8V.
If not you have a truck to camper connection problem.
a) check wire connections, plugs and fuses.
if only one of the batteries are low the battery isolator may be switched off
if starting truck doesn't fix you need to trickle charge the low battery
2) Truck running both voltages read between 13 and 14.5 V
a) if truck battery is low you have an alternator regulator problem
if camper voltage increases but is low there is a connection problem
c) if camper voltage dose not increase its probably the isolator
When I met with Marty at ATC to get my camper he said that if the camper battery voltage drops below (some level 11V?) the battery isolator will not connect to the truck battery and you will have trickle charge the battery. I haven’t had this problem but I have noticed with the 3-way fridge set to 12 V and the truck idling, I can hear the isolator switching on and off every second or two.
Otherwise there is a connection problem (check both white wires and black wire connections) or blown fuse probably located next to the truck and/or camper batteries. In my Palomino I found there was an additional inline fuse between hid under the sink that connect to the truck battery but thats another story. If while running the truck the truck battery voltage is 0.5 V or more than the camper battery, there is connection problem between the truck and camper.
2002 Tundra AC 4x4 with 2015 Ocelot
2006 Tundra AC 4x4 with 2018 78" Ocelot
2011 Tundra AC 4x4 with 2010 78" Ocelot
#19
Posted 30 April 2017 - 10:11 PM
2001 and 2 came with a 3-way fridge.
Brie when going down the road do u have the fridge set on battery mode?
3-way on battery mode draws 12 amps per hour. The alternator may not be keeping up with the amp draw plus turning off the engine for even brief times can kill the battery.
Reminder 80 amp batteries have only 40 amps usable . 40 divided by 12 = 3.5 hours before voltage drops below 12 and SurePower disconnects the alternator to save the truck starting battery.
Edited by RC Pilot Jim, 30 April 2017 - 10:19 PM.
