What are the must have add ones? From ATC or self built. I'm about to order!
#31
Posted 02 November 2017 - 06:58 AM
#32
Posted 02 November 2017 - 02:08 PM
Count me in the "don't like my rotopax" camp. Unfortunately I am kind of stuck with them as I designed an opening around two 3 gallon packs. I have three problems with them:
1. They are really inefficient, with the flat shape and molded in nooks and crannies they take up a lot of volume and don't store much gas.
2. The mount is poorly designed. If you hand tighten the mount up in the morning or evening, by the heat of the afternoon the mounting surface on the cans will swell and you cannot get them off without some sort of big tool, which is not provided. This is with the 'deluxe' mount, with the standard mount you would have no hope of removing it.
3. The lock for the mount (which is one of the reasons I chose them) is junk - in less than a year it has corroded internally to the point that I can't trust it and no longer use it - this is in low salt, low humidity Colorado. If you are making a product specifically to mount on the outside of vehicle at a premium price, make the parts out of brass or stainless steel or something that doesn't rust!
Get a regular 'jerry can' style gas can and mount, you will be much happier.
2016 Fleet Flatbed
2016 Toyota Tacoma
#33
Posted 02 November 2017 - 02:27 PM
We use the AT gas can carriers and like them- they are dual purpose and can carry ammo storage cans as well. We use the Scepter military fuel carriers- they are quiet, don't rust and pour quickly. I made a spout for them.
Edited by takesiteasy, 02 November 2017 - 02:30 PM.
#34
Posted 02 November 2017 - 05:21 PM
Did you make the hold down bracket for the ammo can or is it available from AT Overland?
Just curious, is it not dangerous to mount a fuel can above the hot heater exhaust outlet?
~Jim2000 Tundra AC- 2000 FWC Ranger
2017 Tundra DC - 2017 ATC Panther
#35
Posted 02 November 2017 - 06:30 PM
I like that ammo can mounted in the AT holder.
I made the hold down strap to fit the ammo can. It works pretty well. You can see more pictures here: http://travelswithro...ter-outlet.html
Good question on the heater vent. The heat dissipates pretty quickly from that vent- I have not had reason to worry about it. It is usually pretty cold when we are using the heater and I'm not sure we have ever had fuel cans with us when the heater has been on. Your question will cause me to check it out next time we use the heater.
#36
Posted 09 November 2017 - 12:47 AM
