65L Isotherm 2-way fridge questions
#21
Posted 23 August 2017 - 03:55 PM
http://www.fourwh.co...e-manual-65.pdf
DanoT has a point about winter camping. Although you guys from north of some random parallel are a tough bunch of customers when it comes to less tropical seasons, having cold air from outside exhaust inside the camper and having hot summer outside air with additional fridge heat exhaust inside the camper seems less than ideal. The air exhausted must be replaced with air from somewhere.
I was able to use wire ties to mount a very light fan to the upper vent on my Hawk, it will be tested over a upcoming trip to your Rockies in hopes of actually seeing the mountains this time.
#22
Posted 23 August 2017 - 05:15 PM
the fan is quiet how quiet? i'm not sure i can tell which fan is running so, no louder than the stock one
during the day i have to look at the fan to check if it is running
at night it is more the vibration of the compressor that i notice
i made one vent on the outside wall about 6x6" that goes exactly where the compressor , fan and coils are. there is a direct air flow over the coils from the two fans pushing and pulling together (had to experiment with flipping the fan around to get the flow working so that they are cooperating)
no complaints about the fridge keeps food at 3 degrees C when it is 30 outside
power use is minimal let me check the victron 702--- 12 AH overnight
Edited by Vic Harder, 23 August 2017 - 05:35 PM.
#23
Posted 23 August 2017 - 08:04 PM
Vic, your auxiliary fan is mounted on what is essentially an outside wall, so I suggest that if you plan to do any cold weather camping that you install a separate on/off switch for the aux fan as well as a cover for the fan.
I mostly do winter camping in ski area parking lots, so I have insulated the "outside walls" on either side of the back of my built in fridge.
Good point DanoT. I will look at covering the second fan and disabling it for the winter. The fridge already has an extra 1/2" of pink hard insulation all around it, that I added during the install.
Edited by Vic Harder, 23 August 2017 - 08:05 PM.
#24
Posted 26 August 2017 - 07:27 PM
In 2010 - 2012 Four Wheel was experimenting with Engel top loading fridges in the Hawk and other sizes. Biggest problem was losing the counter space on top of the fridge which pushed them back to front opening models. At rallies I have spoken to owners that have this set - up and prefer it over the front opening models.
I have heard the "Isotherms" are much more efficient than the "Dometics". Top loading portables are very efficient because the "cold" doesn't fall out when the door is opened. Still even in my Engel in plus 100 degree heat the setting is 1.5 and the unit is cycling more often than when outside heat is around 90 degrees.
#25
Posted 17 September 2017 - 03:32 PM
I agree with y'all. My isotherm door never shuts tightly, I've added a bunny lock to hold it closed tight. Pre cool everything. But my spouse served vodka tonic one night with ice, so I know I can make a cocktail once in awhile!
What exactly is a bunny lock? I ask because I am also having trouble keeping the door closed. A Google search turns up some interesting images but nothing that would work on keeping a door sealed tight. I would like to employ a temporary fix to this problem.
I am finding that my reefer door opens and closes while driving down rough roads. It doesn't open completely as the latch has not failed but it continuously opens and then closes but never closes tightly and never stays completely closed. It is always ready to pop open on the next bump and allow more cold air to escape. You can confirm the ability of the door to come slightly ajar by gently pulling on the side of the door when it is shut and watch the light come on and the door open enough to let some cold air escape. No es bueno!
I have reached out to the folks at FWC and they are aware of the problem and have offered some solutions but nothing that works. While I continue to work with them for a lasting solution, I would like to find a temporary fix. Anybody wth photos of your solutions?
#26
Posted 17 September 2017 - 10:45 PM
I own the Isotherm 65 ... great fridge. door stays shut on wild bumpy roads. Was on a ferry for 5 days....no solar charge and the fridge ran well and batteries were fine. I did add 2 quarts bottles frozen. I replaced my Engel top loading with this. Also the fridge is remarkably quiet.
#27
Posted 19 September 2017 - 09:16 PM
I don't have a picture, but I just used a strip of velcro. If you search on the site, some people have some good permanent solutions such as using a privacy door lock or latch, but I didn't want to put a hole in anything. I put a piece of adhesive velcro on the fridge and one on the cabinet, and then use the opposing piece to connect the two. Works great.
#28
Posted 19 September 2017 - 09:17 PM
Good to know. I just need to pull the trigger now. Thanks!
#29
Posted 20 September 2017 - 04:55 PM
I have 65 L Isotherm on my swift, and I always pre-cool my fridge the night before going on a trip. I then load up the fridge with already cold stuff from my house fridge the morning of, and everything stays cold for several days while camping in hot weather. I had no idea the ARB's are more efficient. I have often wondered myself why FWC does not offer more of a variety when it comes to equipment installs. I know some of it comes down to schematics, along with price, but most people are willing to pay for it.
#30
Posted 20 September 2017 - 11:31 PM
I'm happy with the Isotherm on our 2016 Fleet.
It does it's job. You just have to park in sunny spots. The fridge is the main power draw on our system.
If I had to do it again ........
I'd get the camper without a fridge.
Put an ARB fridge in the backseat wired to the truck battery.
Or a Yeti cooler would work for 5 or 6 days.
