Four Wheel Blazer Pop-up, Finally found one
#191
Posted 04 July 2019 - 07:26 PM
#192
#193
Posted 05 July 2019 - 05:37 PM
1996 Dodge Ram 1500 4x4, lightly lifted, ARB bumper/Warn winch, BFG AT/KO2, Snugtop shell. SOLD! But not forgotten!
2002 Chevy 2500HD XC LB 6.0L 4X4, Leer Hi-Rise shell, completely stock...for now!
#194
Posted 06 July 2019 - 10:36 PM
Bosch made H4's to fit those tiny HL buckets. Susquehanna Motorsports may still have some left. Was a large improvement for my '91 Sub.
Where does that road go?
#195
Posted 07 July 2019 - 02:36 AM
I've looked a long time for the e-code Bosch lamp housings. Long gone. If they do pop up on Ebay they want a mint for them. For the what they want for the E-code bulbs I could change the core support for the cheaper version with the dual headlamps and replace the grille and headlight bezels too. At least then I could have many options for quality LED housings with the proper cut off.
The fall back is bending over at LMC for $120 worth of their light housings that take drop in bulbs.
I should just put the HD headlamp relay harness in that I got from LMC but I'll have to swap the plug ends over since they used plugs that don't match the factory H4703 and H4701 bulb sockets. At least I'll get full battery voltage to the lights and get better output out of the halogens.
#196
Posted 07 July 2019 - 06:17 AM
Last i looked the only Bosch housings that you could touch were the high beams. The low beam housings were also used for overseas gm fog lights. However hens teeth and unobtanium are the key words.
Thats why i did the complete core support swap to get the H6054's in play so i had options.
I had the LMC housings. Wasn't thrilled with the beam pattern. I am not sure if Dave aka 6772xtc on ck5 has used them as i gave them to him.
So my 2 cents is ditch the 4/5 year only gm tiny lights for a core support that uses standard sizes. More work...yes...but happier you will be said Yoda...
#197
Posted 07 July 2019 - 01:16 PM
If I find a complete setup I may do just that. It may wait until after the repower project occurs. I got a lot of stuff I still need to buy for that swap so lighting will take a backseat for now.
#198
Posted 06 August 2019 - 03:39 AM
Getting ready for a new adventure. One month out from heading to Moab for Blazer Bash. It's an annual gathering of like minded full size Chevy guys and gals for 3 days on Moab Slickrock. Think Easter Jeep Safari on a much smaller scale and with cooler full size K5's, K10's and other GM truck goodness.
I've got a buddy I've been trading parts with and helping with his FWC Blazer Camper build who is also planning on attending. We'll be meeting up in Salida, CO and driving to Montrose together. He and his son are coming from Denver while my son and I are leaving from Pueblo. Once in Montrose we will get a fresh map of the RimRocker trail and the 160 miles of dirt it covers. We'll spend one night on Rimrocker and pull into Moab the afternoon the following day.
The next two days in Moab we will tackle the Hell's revenge trail and Flat Iron Mesa.
Not much to do to the truck but repack as we get closer. Maybe swap in some fresh plugs as the mileage has dropped and my tune seems to be a bit on the rich side so the plugs may be fouled. Other than that its load and go.
Really looking forward to hitting both the overland style Rimrocker and the slickrock of Moab. Plus I won't be the only FWC Blazer camper out there.
#199
Posted 06 August 2019 - 05:12 AM
One month huh? Just enough time to that big block in there...
Spent the last hour going through the thread Rob. Interesting!
Looking forward to our trip next year when I get to pop-the-top with you guys. Two FWC's, two Phoenix and one French/Portuguese thing I know a bit about.
Edited by Oilbrnr, 06 August 2019 - 06:48 AM.
- 2016 Power Wagon - King/Thuren/Carli/Air Lift/Daystar suspension
- 2017 FWC Hawk
#200
Posted 08 August 2019 - 03:43 AM
Yeah no big block swapping is happening in that time. The head cheese at the BigAssGas Garage won't let it in until the snow flies anyway. I can plod along with the 5.3 as it's still way better than the TBI 350 that was in mine anyway.
Thanks for checking out my build on the camper. It's been an adventure and thank goodness I know people that are much better carpenters than I am. With the new bench layout I really streamlined my packing and access to gear. Much easier than last year with me an Ian filling it to the gills. This next trip will be the first one out more than a weekend and we'll be moving every day similar to the Desert trips. So fast set up and take down are the goal. Seemed like it worked pretty well on the last overnighter.
Having another camper to pop the top with should be fun. Can't wait to check yours out for sure.
Also tagged with one or more of these keywords: K5, Blazer, 4wc, 4wheel, FWC, pop-up, camper, crawlabago
Trucks, Campers, Gear Forums →
Gear Exchange →
2011 FWC Kestrel $16,800 Akron, OHStarted by Smorgash , 15 Apr 2024 Kestrel, FWC, Four Wheel Camper and 1 more... |
Gear Exchange →
2009 Eagle Four Wheel Camper Madison WisconsinStarted by WiscoK , 10 Apr 2024 truck camper, FWC |
Gear Exchange →
FS: 2023 FWC Project M for 5.5' Full Size Beds - $14,000 - Colchester, VTStarted by danruss , 06 Apr 2024 fwc, project m, tundra, 5.5, 2023 |
Gear Exchange →
For Sale: upgraded 2001 FWC EagleStarted by Wildcat , 26 Feb 2024 FWC, Eagle |
Gear Exchange →
2001 Toyota Tundra W/ 2006 Four Wheel Camper HAWKStarted by carlajuliett , 21 Feb 2024 forsale, toyotatundra, FWC, HAWK |
5 user(s) are reading this topic
0 members, 5 guests, 0 anonymous users
