If you haven't got a swing out carrier fabbed yet then I would consider mounting them on the backside of the swing out. Locking the swing out would help deter theft also. Ron
#11
Posted 23 December 2017 - 08:53 PM
#12
Posted 24 December 2017 - 12:48 AM
Excellent suggestion!
#13
Posted 24 December 2017 - 01:15 AM
That's for a pair, Dano.
I haven't made up my mind but I'm leaning toward fabricating a custom mount and mounting them dead center on my spare tire .... if I can ever get a bumper with a rear swing out tire mount fabbed. My tires are pretty damn big so there would only be about 6" of Maxtrax above and below the spare.
MaxTrax makes a spare tire mount that straps around the spare. That and a cable lock is what I use.
#14
Posted 24 December 2017 - 02:05 PM
There are very similar and much cheaper options available:
https://www.amazon.c...ery+boards&th=1
or even less:
https://www.amazon.c...recovery boards
I have some of these mounted across the back of my flatbed between the jack brackets - but if I had a slide in and the space I would mount them under the cab over as someone else suggested.
I have the Maxsa, 32F and they flexed well, I have heard that some of the imitations will crack, so far so good on these. They seem softer and bend well. I have used them a few times on rocks, dirt and sand. So far so good.
Edited by Josh41, 24 December 2017 - 02:07 PM.
Nissan Frontier 2016 CC LWB, 2" lift, tires, airbags and other stuff
FWC Fleet
Summers Off
#15
Posted 24 December 2017 - 11:30 PM
Good to know. The originals are very pricey!
