^ If you didn't get the bed liner coating then skid plate is a good idea for gravel travel (I now realise):
Posted 06 January 2018 - 12:42 AM
Posted 06 January 2018 - 01:01 AM
Follow My Shenanigans: instagram.com/campermccampface
Posted 06 January 2018 - 04:14 AM
Posted 13 January 2018 - 01:06 PM
I had this tank on our Tundra, make sure you clean the inside of the tank out really good before install as ours was filthy inside! I applied undercoating to ours before install (crappy brand that I would do differently if I was to do it again). Overall the tank worked great and the extended range was awesome.
My 4wd Sprinter Build: CLICK HERE
My Unimog U1300L Build: CLICK HERE
My VW Syncro Westy Build: CLICK HERE
My Tacoma/FWC Builds: CLICK HERE
Ride Report - In Memory Of The Crewmen: CLICK HERE
Posted 17 January 2018 - 12:36 AM
how do you find the straps provided? Others have said they are very weak? Maybe transfer flow has upgraded them???I had this tank on our Tundra, make sure you clean the inside of the tank out really good before install as ours was filthy inside! I applied undercoating to ours before install (crappy brand that I would do differently if I was to do it again). Overall the tank worked great and the extended range was awesome.
Posted 17 January 2018 - 01:22 AM
Posted 17 January 2018 - 01:23 AM
is tere a “fix” for this???Transflow provides the new straps with the tank. It’s not the straps that are weak, it’s how they mount to the frame that are weak.
Posted 20 January 2018 - 04:20 AM
Posted 25 January 2018 - 05:58 AM
I reached the same conclusion regarding the tank. Don't think I'll need it, and may be better to just add a couple jerry cans.
Posted 26 January 2018 - 04:38 PM
It sure would be nice if the tundra had a larger fuel tank, I’m not going to deny thatI reached the same conclusion regarding the tank. Don't think I'll need it, and may be better to just add a couple jerry cans.
