Where To Mount MPPT Charge Controller
solar chage controller
21 replies to this topic
#21 Jon R
Jon R
  • 933 posts
  • LocationWashington State
Posted 24 January 2024 - 08:26 PM
Section 4.4 of the MPPT manual covers this. It states that a separate chassis ground “is permitted” because the chassis is isolated from both the positive and negative power connections. Note it does not say “is required.” If you would like a safety ground connected to the chassis you could connect it to your camper negative system (NOT the PV array negative). I chose to leave mine floating and have no chassis ground connection.
Edit: I just noticed you mounted the MPPT charger in your water cabinet. It’s probably a good idea to run a chassis safety ground given that location and the potential for water leakage.
Edited by Jon R, 24 January 2024 - 08:39 PM.
Jon R
2021 GMC 3500HD CC LB SRW Gas
#22 K7MDL
K7MDL
  • 286 posts
  • LocationSnohomish, WA
Posted 02 February 2024 - 08:09 PM
If the controller case is metal, grounding it may help reduce the often reported RFI from many of these units.  Finding a way to do that ground connection effectively is another matter.
2016 F-150 FX4 XLT SCab | Ingot Silver | 6.5' | 3.5EB | 3.55 w/rear locker | Tow | IBC | 7050# GVWR | 1945# Payload | 36Gal | BFG A/T KO2 LT275/70R18E | Timbrens
2022 FWC Hawk Silver Spur | Front Dinette | Cassette Toilet | Cooktop | Hot Water | Outside shower | CR850 fridge | 160W rooftop solar panel | 15A MPPT controller | Dual 90AH AGM batteries | Yakima Rack | 2 Maxxair fans | Furnace | Fiama side awning | Mechanical Jacks
