Hello FWC!
Newbie here. I picked up 4 used corner jacks and wanted to install them on a 1986 Grandby. The camper does not have any jack fittings right now.
The corners are completely sealed with the protective molding. My question is, should I cut the out molding before installing the brackets or can I mount them on top of the molding (see pics). I am concern about keeping it water tight. Even thought the camper is from 1986 it is in mint condition and completely water tight right now. I did look at the Brophy jacks but 4 of them would cost me over $1000 (don't trust myself to use two jacks only) when the four used corner jacks came in under $200. On a tight budget so I decided to go with the corner jacks instead. Any advice you can give me would be much appreciated!
Abbie
