Winter is coming on, temps running lower, check your tire pressures. Just checked mine and found an average of 4-5 lb. drop since the cold front. Don't forget the spare. Happy camping
Tire Pressure Alert
#1
Posted 30 October 2020 - 06:57 PM
#2
Posted 30 October 2020 - 07:48 PM
Great advice.Especially the spare.
#3
Posted 30 October 2020 - 08:09 PM
My @$#%&* truck won't let me miss it.
#4
Posted 30 October 2020 - 10:39 PM
Are you suggesting that with lower temps you want to inflate your tires back up to what they were when temps were warmer? Hmmm. I always thought that "recommended" temps were at 70* F = Cold. If the temps drop, then the pressure is supposed to go down so when the tires are back up to 70* they are at the correct pressure.
2012 ATC Puma Shell build - https://www.wanderth...012-puma-build/
Power considerations thread - https://www.wanderth...e-power-scotty/
Building out an electrical system - So, you want to setup a good electrical system in your camper? - Electrical, Charging, Solar, Batteries and Generators - Wander the West
#5
Posted 31 October 2020 - 02:20 AM
Vic, I'm suggesting that anyone heading out during a cold spell or once colder temps are in place for the season, check and adjust pressure. When weather warms, yes you will need to adjust as needed.
#6
Posted 31 October 2020 - 06:02 AM
Good advice... checking tire pressure, oil, washer fluid, etc. And don't forget to top the headlight Blitzenfluid!
#7
Posted 31 October 2020 - 06:12 AM
Same here. But this year I will do it before my truck sings me a one note song. Although it is about time I pull my spare off and do a visual check.
2017 Toyota Tacoma with 2000 FWC Eagle
"The nut behind the wheel is the most important one. Don't forget to snug yourself up every once in a while." John D & ri-f
