Jack options 1995 Granby
6 replies to this topic
#1 Izzy
Izzy
    Newbie
  • Pip
  • 2 posts
Posted 26 November 2020 - 11:19 PM
Hey there. I just bought a 1995 Four Wheel Camper, I think it’s the Granby. We need to install jacks and we’re trying to figure out the best option.
Our options are mechanical corner jacks,
Truck-titan Tripod heavy duty jacks with #1 bracket,
Or brophy cable camper jacks.
We don’t know what the frame dimensions are on the corners of the camper so figuring out where to drill the bracket to install jacks on the corners seems involved.
We are leaning toward the Reico-Titan Tripod heavy duty jacks but we aren’t sure if those brackets would securely lift the camper or if it may damage the plywood underneath.
Any advice would be awesome. Thanks so much.
#2 longhorn1
longhorn1
    Ouch, that stings!
  • 2,826 posts
  • LocationCarmel, Indiana
Posted 26 November 2020 - 11:25 PM
First thing to do is contact FWC. The newer campers have a a solid piece of wood in the corners. There is frame and wood. You need to know what the construction of the corner is before you do anything.
http://texaslonghorns01.blogspot.com/
Ford F-250 Long bed, 2014 Grandby
#3 BBZ
BBZ
  • 666 posts
  • LocationGolden, CO
Posted 27 November 2020 - 02:44 PM
I have an old Grandby and stripped it to the frame. There was zero support in the corner for the mounted type corner jacks.
I use the big old cable jacks with the big platform (the kind that uses only one on each side and you find the balance point), however, I have 4 of them so I don't have to balance the camper because its sketchy as hell...  works great, quick and easy as nothing is bolted on the camper...
2023 F-150 Scab HDPP + 2013 Grandby Shell +
https://www.wanderth...ect-90s-granby/
#4 JaSAn
JaSAn
    Grumpy Old Man
  • 1,105 posts
  • LocationMinnesota
Posted 27 November 2020 - 04:22 PM
Same here: old Grandby and four cable jacks.  I load in the spring and unload after hunting season.
Renovating Skoldpaddan
2012 Ram 2500 4X4
1951 Dodge Power Wagon
#5 BBZ
BBZ
  • 666 posts
Posted 27 November 2020 - 04:33 PM
FYI - I take mine off and on all the time as I need the truck for work.. you can get real efficient with it.. mine sits on harbor freight trailer and have it at a height so that I only have to jack it up a few inches to load..
#6 Izzy
Izzy
    Newbie
  • Pip
  • 2 posts
Posted 27 November 2020 - 08:47 PM
Thank you all so much for your feedback.
As far as the cable jacks go, I’m living out of my camper, minimal storage. Does anyone have info on how bulky these are to store inside the truck vs the Reico-titan tripods?
I talked to FWC and he said that the brophy cable jacks are extremely precarious unless you are on level concrete. I’ll have to unload mine on dirt or sand. Anyone have experience with this?
#7 JaSAn
JaSAn
    Grumpy Old Man
  • 1,105 posts
  • LocationMinnesota
Posted 27 November 2020 - 10:00 PM
Cable jacks are not something you are going to want to travel with, they are large, bulky, and heavy.  They are a load the camper and leave them home appliance.  They need a solid surface to rest on.  I have loaded/unloaded on grass & gravel but put solid footings (concrete patio blocks) under the feet.
The one person I know with tripod jacks leaves the jack mounted and just stores the tripod feet.
You do know that the camper floor must be supported when occupied off the truck?
Camper must be dropped to the ground or some kind of floor support must be used.
2012 Ram 2500 4X4
