delete
11 replies to this topic
#11 trdt44
trdt44
    Newbie
  • Pip
  • 4 posts
Posted 16 May 2021 - 12:32 AM
OK, here is what I have decided to use in the bed for the connection between the Four Wheel Camper and my truck. The system can accept 6 AWG wire and handle 70 Adc and this is what each wire will be used for:
  • 12 Vdc at 30 amps running from vehicle battery to DC charge controller
  • ground running from engine block to DC charge controller
  • 12Vdc running from 7-pin trailer connector to camper running lights
MARINCO 70A 3-Wire Trolling Motor Plug & Receptacle Combo
Thanks for posting this. I was looking for a simpler plug than using the Anderson connectors. I was not looking forward to running another connector for the running lights. I can confirm this will work with 4 awg wire just need the 4 awg ferrules. Installed mine today as I get my Hawk this week. The DC to DC charger I am going to install will only draw a max of 60 amps so this perfect.
I did find a surface mounted holder that would hold an Anderson connector on Ebay. It looks to be 3d printed and came from Australia. That is what I was going to use until this plug came along.
  • 1
#12 Jon R
Jon R
  • 936 posts
  • LocationWashington State
Posted 18 July 2021 - 04:09 AM
Safe travels, Chet! I hope everything goes smoothly for you.
Jon R
2021 GMC 3500HD CC LB SRW Gas
