Loading Bobcat onto first gen tundra
#1
Posted 03 April 2021 - 06:30 PM
#2
Posted 03 April 2021 - 07:24 PM
I think you might need the extenders.
I have a Bobcat on a 1st gen Tundra with flares
but my camper doesn't have corner jacks.
It has to be loaded/unloaded with the tripod style jack.
I just measured my camper. The flares stick out about 4" past the side of the camper.
So I think extensions will be needed.
#3
Posted 03 April 2021 - 07:33 PM
I had a FWC Ranger on a 1st gen Tundra and my jacks came with the stock folding extensions and that still wasn’t enough. I had to add and additional 1/4” aluminum extension.
I was surprised when I drove from Colorado to Idaho to pick it up. Luckily the storage lot had tripod jacks which we used on the front. It barely worked.
As for the turn buckles, ATC extended my front one with some large quick links. You might just take a number of then with you just in case.
~Jim2000 Tundra AC- 2000 FWC Ranger
2017 Tundra DC - 2017 ATC Panther
#4
Posted 03 April 2021 - 08:35 PM
My Bobcat measures 72 1/2" outside,side to side.
#5
Posted 03 April 2021 - 11:02 PM
Thank you!
#6
The ATC site lists the overhang bed as 69” wide so the camper outside dimension may be slightly wider.
Thank you!
