I'm trying to understand how the system works and the literature that I got with the used FWC isn't much help. If I drain the water tank from the valve at the back of the camper, does that also drain the water heater? When I fill up the water tank, does that also fill the water heater? If not, how do I fill the water heater? I don't want to flip the water heater switch on and burn out the water heater.
Thanks,
Gregg
